I'm currently experiencing some issues with my R33 GTR V-Spec.
I will try to explain as best I can the issues I'm having and I apologise for the size of this post. Please only post constructive comments.
The Problem:
I keep getting the air bag LED and ABS LED in the dash coming on after about 15 minutes of driving. (Air Bag LED constantly flashes, ABS LED is solid) They only light up when the car is in gear, and turn off when in neutral position. This is regardless of what speed I'm doing. So it seems to be related to the driveline being in motion. This doesn't bother me too much, but what does bother me is the burning smell that follows coming from the boot region. The cabin of the car fills with a chocking smell, making it hard to breath. I don't believe this is an electrical smell. It is an indescribable smell, possibly an oil burning.
2nd Problem:
HICAS system. I have just installed a nismo dash and found that someone had removed the HICAS warning lamp from the original dash cluster. So on the nismo unit the HICAS LED is on at all times. I have done no further diagnosis on this. (Could be related, could be seperate issue.)
Background:
I have owned this car for 5 months, and believe it is a very stock unit, with the only modification being an exhaust . I attended a skidpan day, where I removed the front drive shaft and drove reasonably hard. The Monday after this event my GRID dash dancer (Electronic torque split controller) arrived from Japan and was installed, by RevZone. When I first drove the car after the initial install, The Active LSD and 4WD light in the dash came on. I drove the car at 10km down the street and it felt like the hand brake was on. (the car didn't want to move) I turned the car off and on again and the lights were gone. This has not happened since.
I have found the GRID unit diagram translated into English, and re-connected (soldered) the wiring myself. I have also removed the dash dancer from the vehicle and found that the problem didn't disappear, but only happened twice in two following weeks of driving. So the problem is reduced when the GRID Dash Dancer is removed, but it's not the source of the problem. The Dash Dancer it's self appears to be working in normal (disabled/ off) and rear wheel drive mode, but 50/50 split isn't working.
I have had another mechanic check and bleed my hydraulic lines, in case there was any problem there.
I have purchased and installed redline oils for both front/ rear LSD's, Gearbox and Transfer Case. When removing the oil from the transfer case I found a spring loaded washer stuck to the sump magnet. (May or may not be related)
Any help would be most appreciated. Especially from someone with similar issues.
Any recomendations on mechanics that would know about driveline problems in GTR?
Thanks, Chris. (Scotsman)
https://www.sau.com.au/forums/topic/38680-r33-gtr-driveline-issues/
Nah I don't think the smell I'm getting is brakes. It fills the cabin only and cant be smelt from outside the vehicle (I know what burning brakes smell like) The smell originates from the inside the boot.
leaking hydraulic fluid onto something hot like the exhaust and you can smell the fluid burning on exhaust from inside the cabin/boot area? that would also somewhat expain your hicas /abs lights coming as the system is leaking fluid and could be malfunctioing?
park it on some clean concrete or road and fang up and down a bit, any drips etc??
sorry if this doesn't help, just picking stuff out of mid air
there was another thread where someone had changed the steering in a gtr without the proper hicas boss kit and after 15 minutes or 10 minutes the hicas system would think there is a malfunction and bring on the warning light cos it could not sense the steering motion.
maybe search and see if there's a match somewhere there
I second the motion for a problem caused by after market steering wheel fitment. If you have one and the incorrect boss kit is fitted it will cause problems. Your HICAS light will come on due to sensor confusion in the steering column. It causes the hicas to shutdown and the fault light comes on. Pretty hard to see if it is or isn't working on the street... (being sensible of course.. eh eh)
Further, if your lights seem to come on intermittently try doing this: turn on everything you can and load up the electrical system and see what happens. Air con/ demissters stereo lights the works.
I've seen instances (on an r33 vspec) where due to a grounding problem the 4wd system will drop out when the electrical system is heavily loaded. When put on the r32 consult computer at Nissan it pointed toward the TPS having a fault but it ended up being a grounding issue.
If you've ever had an engine out or you suspect that its been out it might be worth checking to make sure there's no problems with grounding.
Remember the wiring harness is almost twice as thick as an r32 for a number of reasons so using the Nissan R32 consult computer system test will only check about half or so of the circuits. Its not the gospel test but it is very useful to help troubleshoot problems.
It sounds to me like you have a few seperate problems that are causing confusion.
Good luck with it.
Sebaz
2nd Problem:
Background:
Chris I put a Nismo cluster in my car today and have also found the same thing as you. Please let me know if you have yours fixed as yet coz that light is already giving me the shits after 10 mins
Regards Alan
Maybe someone has removed or played around with the HICAS unit and havn't put it back together again properly.
I would doudt that you would have a stock car, it may have come to you seeming stock, but it doesn't mean the owner before you hasn't done anything.
I've read/know some people that do up their cars and when they sell them they rip out all the parts and put all the old parts back in and then sell the car.
HICAS switched on after thrashing the shit out of it... and only when i thrashed it for about 10 minutes straight.. not letting it rest.. i took it to JSV for a service and the next thing i noticed it never appeard again.. just call them up and ask to speak to julian.. hes a good bloke ..
let me know how you go with the grid danser.. i don't feel comfortable leaving mine on 50/50 either, it feels like the drivetrain is twisting.. 0/100 seems to work well enough though (apart from the odd 4wd light error coming on after a few attempts at traction loss)
i had some very bizarre occurances with the grid danser when i accidently wired it the wrong way around, might be worth a check (i have instructions in the FAQ/tutorial section)
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
