What am i looking at for the right injectors, as can do them before do the computer, the Mines can compensate enough for now, and i was thinking bout the turbo upgrade. No intentions to go E85. I also dont want too big a turbo as i am not out for brute power, but quick fast spool and a little bit more punch, say max 18psi perhaps?
How much for the turbo?? And how much work has it done? Would it be bolt on or require lotta mucking around, as i am keen to only get one that will bolt right in.
Edited by J'son
550 cc injectors can handle 250kw quite easily I was told.
Thats what I am currently looking into. :thumbsup:
Pass me the details at the end of your research, i'll see how my budget is. Hope they are something i can install too...
This is what found elsewhere, is this the same?
garret gt3076r
BALL BEARING 60 TRIM COMPRESSOR
59.8mm Inducer / 76mm Exducer (Compressor)
60mm Exducer / 54.8mm Inducer (Turbine)
Internal gated rear housing
What price for it and how old and how much work has it done? I'm fairly keen<br style="line-height: normal; text-align: -webkit-auto; background-color: rgb(255, 255, 255); ">
Injectors might be a bit fiddly to do yourself, seeing as you have to remove the top half of the intake manifold (not ABSOLUTELY necessary I've heard, but recommended)
Yes it is similar to the above but a little better as it has an .82 rear housing and the piping to go from 4" down
It has appx 4000kms or less on it. It looks brand and feels brand new. Welcome to check it out.
Ideally the kit I have is bolt on for a 34GTT complete thats why I got it. I'm asking $3k for the lot.
Id rather not seperate the Turbo from the other gear as it gets harder to part out bit n pieces.
Although the Turbo only costs $1500 or so the other parts add up and there all near new.
- Z32 AFM
- A proper garret spec GT3076r kit from GCG with the .82a/r housing and 4inch surge slotted inlet
- Blitz SpecR dual solenoid boost controller, wiring and display
- Bosch 73LB(~750cc) EV14 injectors
- A tuned Nistune ECU (by Trent at Status/Chequered Tuning, 304rwkw)
- Nismo fuel pump
Hope this helps. I do have someone saving like mad to get all of the above. We'll see :thumbsup:
PS. The pipe for the afm and the Nismo fuel pump I havent taken pics of, yet...
Sounds sweet. But i cant afford that.. I cant spend over a grand really, but woulda spent around, inc labour.. It is a sweet deal, but would have to see if would work on my car well, what extras and changes i'd need ect... I wish was all easier, but cant really....
looks so perfect and wish could snatch it up, but i dont have that cash free... and the install would be more than i could do myself, so then need more cash for that ....
Cheers for the offer, and wish could snap it up.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
