Hey guys,
Recently acquired one of these beauties and need some little things to get it up to scratch... most things are very small.
Here's the list.
- 2x Clips that secure the stock air snorkel to the front radiator support.
- 4x Clips that secure the lining in the boot / near the lights and side areas.. There those twist half out and pull kinda ones.
- 2x Clips that secure the plastic cover on the boot hinge.
- A Nismo Gear knob .. the leather style/stitched ones. My stocky is showing signs of wear.
- The tray the pulls down on the right bottom of the dash, mine is busted on one side and it doesn't hinge too well.
- 2x Washer nozzles for the bonnet IF they are meant to be black normally .. (mine looked sprayed silver?)
- Nismo Clear side and front indicators.
- There is some type of solenoid at the back of the motor, mounted to a bracket, one electrical connection and 2 vac hoses to it.. i need one of these.
- Apexi or Nismo GT Radiator Cap
- Nismo Billet Oil Cap
- My car has 2 red lenses in the doors for courtesy lights, but no lights/fittings behind them... does anyone have these fittings? What models had them hooked up?
- A nicer strut tower brace, Nismo perhaps .. show me what you have!
- I know this is kinda wanky, but anyone have a kick panel flare? Mine's been removed! (wanted to make it all as original, not spending $100+ though...)
- One of those boot corner mounted sub boxes
That's all i can think of at the moment. Please let me know via this thread or PM if you have any of these or can help out in any way.
Thanks, Kurt.
https://www.sau.com.au/forums/topic/386923-shoujikis-wtb-thread-for-r34-gtt/
I also have the bottom right tray on the dash not hinged properly to the side and loose, and also have no lights/ fittings on the red door courtesy lenses... Hmmm dunno if its meant to be that way. Plus have clips missing in some of the boot trims as well..
Seems like people are just messy when doing work and don't put stuff back properly! Common thing with people that don't know how to work on cars and take care of them haha!
Yeah I'd say the courtesy lights are wired up for certain models. I'm sure the GTR has them in, as i've seen a few lit up. They must just use the same door panels. I'd like mine working though, be a nice touch.
Got a few parts already from some great members here, thanks so far!
So far have got :
I also have had 2 offers for a flare (which i appreciate!) however there sold without the holder, mine has the holder removed, so I'd need that too. Around $50-60 is all I can swing to.
Bumparoo up you go!
Edited by Shoujiki
Hey Redline GTR... Yeah i actually found all the clips for my boot and what i needed from a local wreck here in Victoria... he still has quite a few on the car so give him a bell ... he has a R34 wrecking thread . Suji is his username.
So i need these last few things:
- GTR Courtesy lights/brackets/plugs from the doors
- I have the flare now, BUT, i need the "holder" part that screws to the kick panel itself .. anyone got a car that has the flare removed but still the holder?
Thanks!
Edited by Shoujiki
Have sourced a flare and holder from an awesome member that gave me it for nothing! So, just the final things on my list left now above, anyone help out?
- GTR Door Courtesy Lights
- Plastic Trim that hides the screws that mount the driver side mirror, interior panel. Commonly where people put spllt tweeters. (mine has a busted clip)
Bump! Updated and removed parts I have sourced and now have. Added in one more interior panel, not sure what you'd call it but it's a panel that hides the screws for the drivers side mirror, its a triangle shape with 2 clips. Mine has 1 busted clip so need a new panel.
- A nicer strut tower brace, Nismo perhaps .. show me what you have!">
Updated!
Edited by Shoujiki
Bump! Just need these last few bits!
  • 6 months later...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
