Hi All,
I've got the following for sale.
HKS GT-RS Turbos x 2 (changed the wastegate to GCG 24psi as the HKS wastegates were leaking boost and couldnt go beyond 24psi)
HKS Dump Pipes x 2
Tomei Expreme Exhaust Manifold x 2
Kakimoto Frontpipe 3.5"
Looking to sell it as a whole kit. Turbos, Manifold have about 2000km on them. Kakimoto Frontpipe & Dump pipes have about 10000km.
Great condition, i have run 441awkw @ 24psi on caltex flex fuel. I have pictures if you require. Selling the kit as I am looking to go a bigger single turbo for a new engine setup.
Price is $4200ono. Offers welcomed. Parts priced new is an easy $6000. It is still currently on the vehicle but can have them off within a day.
Gordon
0432 820 820
https://www.sau.com.au/forums/topic/387573-fs-turbo-kit/
If it wasn't for the leaking actuator. I shouldve got close to 500 @ 30psi i'd say. Power is based on a 2.6l bottom end however.
If i am unable to sell the kit soon, i will just keep it and just leave them in the car tuned on 30psi.
https://www.sau.com.au/forums/topic/387573-fs-turbo-kit/#findComment-6180315
Looks like the last 2000+ rpm has over 400wKw! Awesome stuff... beats my 310 from GT-SS and 17psi... interesting the graph looks the same only yours has much high numbers... Fully boost around 5000-5500rpm?
https://www.sau.com.au/forums/topic/387573-fs-turbo-kit/#findComment-6181822
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
