Marulan T-T is the ultimate time trial experience!
An exciting way to enhance your driving techniques while enjoying an interactive challenge.
All experience levels are welcome as drivers will be grouped by lap time on the day.
Each driver will dial in their own time at the start of the day and aim to match it during each session. Consistency is the key to improving your driving skills and techniques!
There will be Advanced Driver Instructors there on the day to offer tips and advice for those looking to take their driving to the next level!
When? Saturday 25th February, 2012
Where? Marulan Driver training centre
Contact JMP Motorsport - [email protected]
Price $185 per driver
www.jmpperformance.com.au
Click here to download the Marulan Time Trial Info Pack
https://www.sau.com.au/forums/topic/387812-marulan-time-trial/
Marulan Time Trial is a new concept motorsport event, which encourages motorsport enthusiasts to challenge themselves and test their skills and ability on track.
The best part about it is you don't need a prepped race or track car, you can take street car out there too. It's not about who is quickest over the line, its all about driving skill. Consistency is the key.
Federal Tyres is supporting MTT by providing prizes and tyre vouchers and will be there on the day to offer advice and recommendations on tyre choice. JMP Performance will also be supporting the event and offering competitors prizes and vouchers.
Professional Advanced Driver Trainers will also be present on the day to offer advice on driving skills and techniques to improve your consistency and results on track.
JMP Motorsport is offering Skylines Australia club members an exclusive deal for this debut event – 15% off each entrant price for a group booking of 10+. This means you will pay just $160! Make sure you get in quick before spots fill up, there are only very limited entries for the day to maximize track time for the competitors.
To book head to the JMP Performance website and make sure you enter SAU in the Car Club section to be eligible for your discount - http://www.jmpperfor...om.au/events-2/
Edited by JMP Performance
Each session will be about 7 minutes for a group of 4-6 cars. Multiple sessions through out the day. You also have practice/ qualifying in the morning.
We have divided sessions and post session reviews all into sections to allow for quick track clean ups if necessary. As this is pure Time Attack not drifting the risk of track debris is reduced.
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
