Driving sports
Project d
Driftmob
Are the best places to keep your eyes peeled. There's a day at the creek mid Feb happening under one of those guys. Best bet would he rock up and ask a few of The more serious guys face to face. They're generally pretty friendly and would know exactly what's going on.
https://www.sau.com.au/forums/topic/387848-nsw-drift-scene/#findComment-6183051
