As per the title I have 4 R34 GTT rims with Toyo R888 semi slicks.
The rims have painted black. They are straight and the only damage is some paint chipped off from the socket changing them and the tyres being fitted.
Toyos are R888 GG 225/45/ 7R 17 94W.
The tyres have done 6 tracks days. Two of them are probably at 40% so would get a few more track days. The other two have flat spots but have the same amount of grip as the other tyres. I was running them on the back wheels OK but really they are only good for skidders.
Looking for $550 ono.
I am in Bayside of Brisbane.
Can freight at owners expence. I think with E-Go it should only be $100-$150 going off other peoples threads.
https://www.sau.com.au/forums/topic/388332-r34-gtt-rims-with-r888/
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
