I'm suprised this hasn't been established already?
who does swimming around here?
how far do you swim?
how long do you swim for?
do you swim in a pool or the ocean?
Does anyone do any open water races??
I swim 3-5 times a week, anywhere from 2-4km in the Ocean.
https://www.sau.com.au/forums/topic/388775-swimming/
Damn I haven't swum properly for years...tested my bi-lateral breathing the other day and I still have it :D
Used to love the swim carnivals as a kid/teenager and swimming in squad. Now find the idea of swimming in a warm public pool a bit :/
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6196228
birds...
get out in the bay mate!!!
only when it is clean though!!
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6196236
Tommy Hafey swims in the bay 365 days a year. No shit he told me. Champion.
The Harold Holt pool has an awesome 50m outdoor pool which in the winter is awesome and spooky, love going late at night when the condensation is rising and you get out and it's freezing cold.
Usually just swim 1km breaststroke but not so much of that in my routine at the moment.
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6199923
I hate the ocean, love to swim in pools though.
I just dislike the salt, sand and have an irrational fear of jellyfish, sharks and stingrays. Hell, I don't even like crabs.
I am opposite I love the ocean, ok with outdoor salt pools... Hate indoor pools...
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6215476
i reckon it depends on what temp the pool is at, prefer outdoor pools with temp less than 18 degrees.
bay at the moment is around 19 degrees.
Optimal temp is 15 degrees... but i swim all year round! winter and everything in between!
get's to 6 degrees.
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6223036
  • 3 months later...
  • 4 weeks later...
  • 1 month later...
Posted earlier about stroke correction. The highlight of the week is now my weekly coaching session. Having a coach through the winter has kept my motivation up, the drills and technique improvement she has given me has been money well spent and enjoyed.
Edited by DR 32R
https://www.sau.com.au/forums/topic/388775-swimming/#findComment-6482477
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
