Hey guys,
After a long time thinking about the direction in cars I want to head in, I have sadly decided to sell my very first skyline.
I am the first owner of this car in Australia, purchased it in October 2008 completely stock from Kamikaze Motors.
I have purchased all the parts myself and had all mods installed by Le Mans Automotive in Templestowe.
Serviced every 5000KMs
1996 - ECR33 - GTS-T - RB25DET - Manual
141K on the clock
AR1 - Super Clean Red II / Nismo Racing Red
Factory Sunroof
Tein Mono-flex Coilovers
Hel Braided Brake Lines
DBA 4000 Front Rotors
Project Mu B-Spec Front Brake Pads
Project Mu Shims
Greddy Oil Filter
ARK Rev Shift Timer
ARK Advanced Boost Controller
Blitz FMIC - Return Flow CS
JJR 3" Bellmouth Front Pipe
X-Force 3" Stainless High Flow Cat
JJR Rear Strut Brace
Front Strut Brace - unknown brand came on car
JJR Hicas Lock Bar
O2 Sensor Replaced 10,000KMs ago
Autometer Boost Guage
Wed Kranze ERM 17" x 8.5" gtr offset 2.5" dish
Yokahama S-Drive Tyres
Sony CDX-GT170 black/red Headunit
Pioneer Carrozzeria Tweeters
Pioneer Carrozzeria 6" front speakers
Sony Xplod 6" 4 way rear speakers
Sony Xplod XM1S Amp
Sony Xpod boxed subwoofer with grille
Replaced windscreen 10000KMs
+Few other parts here and there
I will also be including
APEXi pod - used for 1000KMs
Nismo front lip - in silver
Series 2 optional black mesh grille with red S
collection of shift knobs
Stock R33 Wheels x4
Stock SMIC, brake lines, front pipe, cat, shims etc
I have receipts for everything and these are available for perusal
The car has never been to the track and boost never pushed above 8psi
seats always covered with seat covers
car has a small dint on bonnet, could probably be popped out very easily, and a 50 cent coin sized chip of paint off the front bar from someone reversing into me
im asking for $9750 ONO
Send through a private message if you have any questions
Thanks
post-55700-0-19494500-1327129819_thumb.jpgpost-55700-0-58323800-1327129871_thumb.jpgpost-55700-0-67688400-1327129881_thumb.jpgpost-55700-0-92484000-1327129898_thumb.jpg
Edited by bluejeans
https://www.sau.com.au/forums/topic/388959-r33-gtst-series-2/
  • 1 month later...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
