Hey guys new to these things, i bought a 25det 33 a few months ago with a few probs, basically wastegate was half open from previous owners doing a crap job of bolting in a 3076, have flushed cooling system, radiator has been stripped and cleaned, has a new thermostat (rb30) and system has been bled as well as i can (using bleed screw) i put a new genuine rad cap on the other day and when cold i can squeese top hose and make oveeflow bubble? Is this normal? Gets hot on my hill which is 6 kms of uphill but even cruzing the needel rises fast, chem test shows no co2 in cooling either, please give me some ideas
https://www.sau.com.au/forums/topic/389153-r33-gtst-rad-capcooling-system/
When the car is cold start it up with the radiator cap off, let it warm up and add coolant if needed, then replace the cap and shut it down, when it cools check the level and top up if needed.
Ensure the overflow bottle is at the high point throughout this proccess.
This is how I do it anyway.
start with a new radiator cap. pretty sure the stock pressure for the cap is 0.9bar. make sure you get one that is the stock pressure. don't get a higher rated cap.
if that doesn't help the situation then i'd look at getting a new water pump. it may be that it wasn't changed at the 100,000km service (if it's been done) and they can wear out to a point where they have no blades left so they don't pump water.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
