Anyone seen these before?
http://www.ebay.com.au/itm/18inch-GUNMETAL-Deep-Dish-GT-C-Wheels-Tyres-STAGGERED-/290657927869?pt=AU_Car_Parts_Accessories&hash=item43ac9002bd
They look quite nice, good price too but im wondering................... are they heavier than the moon?
https://www.sau.com.au/forums/topic/389164-18inch-fleabay-alloys/
If you want light weight, you'll probably end up paying for it.
But, do you NEED light weight?
If you just want a nice set of wheels for the street, they would be fine.
If you want to cut every .1 of a second of a lap, you NEED to purchase accordingly
i just did,
its 17" and they are 2 for $150. so 4 = $300.
18" would be at least $100 a pop so 4 = $400,
got me excited mate.
Hahahaha............. :laugh:
I've dealt with those St George Tyres guys a few times and they are pretty easy to deal with, they get some strange imported tyre brands though LOL and the grip from them is amazing.................ly non existent :rofl:
achilles ATR sport from st george tyres.
good mob they are.
Cool, gotta order some 235's for dad anyway so might as well get some skid tyres for the rear of mine while i am at it :thumbsup:
Say :action-smiley-069: to grip?
mine too, it was a typo, it was suppose to be 148rwkw.
:rofl2: I think we've spammed this thread enough!
But on topic, ST George are cheap and easy to deal with and them rims are CHEAP!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
