Hi guys,
My project involves putting a 4.11CW&P onto an S15 helical centre into an R32 housing. Three diffs are gutted, useful parts put together. But the setup of the diff is troublesome.
My mechanic has stuffed around for a few hours and hasn't been able to get it set up right with the various thickness washers he has available. It's time for it to go off to a diff workshop to get set up so he stops wasting time on it.
I'm just looking for any recommendations for trustworthy diff shops in Adelaide who won't charge like wounded bulls. My mech usually takes stuff to SA Race when he has to, and I'd be happy to use them, but input from others who have used any other diff shops will be appreciated.
cheers
https://www.sau.com.au/forums/topic/389367-diff-workshop-recommendations/
Hey bud I have built and set up many of these diffs I am more than happy to help over the phone if you want. We are in Newcastle NSW so it would not be worth sending it over. PM me if you want to chat.
Cheers Ryan
Hi Ryan, My mech knows what he's doing, but he has a limited supply of different thickness washers to get the CW&P right. After stuffing around with what he had available he declared it to be time to stop wasting time and get it done by someone who can go straight to the answer instead of going round and round. My last contact with him was an sms on wed arvo. I'll have another chat with him direct tomorrow, and I'll get back to you if he thinks your help will help, if you know what I mean. Thanks for the offer. cheers
Well he does.....but they're a race trans and diff shop with no need to give me nice pricing! It's a shame that over the last few years, the nearby diff shops that were trustworthy have all shut up. There were two or 3 and now there's not so many choices. I was just looking for some fresh options.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
