http://www.carhistory.com.au/
what's going on terry?
As I implied earlier, PPSR is second rate compared to VEDA because PPSR doesn't supply info about odometer readings, nor current car value, nor whether it might have come from the Lockyer Valley Qld last year and had had flood damage.
CarHistory is part of the VEDA Group.
What I wonder is, did the Sydney Morning Herald reporter only quote the $3.70 fee for a 'verbal'; or a basic report without the frills?
CarHistory will charge $33 approx for a comprehensive report on a car.
And how much info will they supply for just a 'verbal'?
  • 1 month later...
didnt want to revive, but its fairly new still....
anyway, im a bit confused now on what to use after reading this :S, im in syd and i want to check the history of a car (currently rego'd in qld) what do i use now? :S also how about if the car is in NSW what do i use then? - will options given give national wide register info or just the state the car is currently in or i am in?
Edited by Ezy03
Best to use VEDA because it's national.
Used Car Dealers use VEDA.
REVS is only state - and VEDA uses REVS along with others.
REVS won't pick up a flooded car from Lockyer Valley if you're in NSW; nor an interstate cut n shut eg repairable write off
thanks man, i just checked out (again the veda site) and clicked on the personal link - car history. and it seems to go to carhistory.com.au, guessing that's the one that checks everything in every state the car has been?
That's it. All the best...
thanks man, ill be doing one or two soon, and ill see how it goes, ill post up my experience etc for those interested. btw they say cheaper but its still some $30 odd dollars per car..which is kinda expensive, especially if you just want to check a car before taking a long drive before viewing it or even contacting a person who's selling it.
  • 4 weeks later...
Biggest problem with this site is:
I've gone to use it twice in the last monthish, and it comes up that 1 third of the data base is down.
Now, you can't see if the car you're looking at is on that portion of the data base, without paying first.
It states, if you pay, and the car doesn't come up, they will send you the certificate when the system is back online.
How does that help me now?
If the cats not registering yet, and I pay for said certificate, and buy the car with any problems, are they going to reimburse me?
Doubtful.
When i checked for the Sil80 I bought, it came up as not on their system.
I'm pretty sure at that stage, they didn't debit my credit card.
But the new policy states they will.
I would like to see a similar system to the old revs.
Here's your info.
If you want a legal copy, pay and we will send it out.
If you just print it out, it won't be worth the paper you print it on.
Just my 2c
/rant.
  • 5 months later...
Both PPSR and Carhistory are a complete f**king joke of a system.
What a waste of money, they won't recgonise all Victorian cars, kept saying rego and VIN don't match up in their system when Vicroads does.
For the money they demand to run a check, I'd expect them to do everything right - I don't want excuses such as 'it's new, give it a time' for $33 per check it's unacceptable really.
Bring back written off and encumbrance status on Vicroads vehicle check I say, they can afford to give out free service since they take our money on rego and not fixing the roads...
/rant
Wow, i am impressed with the improvement this is going to have on the standard REVS check. I use REVS on nearly a daily basis being in the car industry, it only tells you if the vehicle is written off or encumbered (money owed) then i do a PPSR which matches the VIN number to the actual description of the vehicle. But it doesn't cost me a cent to do checks which is a bonus :)
This VEDA seems to have a lot more information, looks good!
I didn't think veda/car history did imports? I tried them with my old 34 and they couldn't look it up cause there's a few too many digits
the old revs system could.
purchased a certificate when I bought my gtr due to it being cheap.
the last couple of times I've tried using the new car history crap site, it won't display, so can't print.
they only give you 3 days in which to find a computer that can print it.
and, even if it can't find the details, they still charge.
BRING BACK REVS!
the system where you could try before you buy.
and paid for the proof you could see, not a whim and a prayer.
  • 1 month later...
Sorry for the revival.
I have put in 2x R33s and neither are valid. (at least I didn't have to pay yet!)
I ended up phoning them, and they then passed through the VIN so I can now search online....so long story short, if it doesnt work - call them, and if you are selling, maybe call them before your buyer cant find the info and walks away :)
Edited by eXc
Talk to Todd at JapLink Motors who has access to the commercial arm of VEDA.
0425857680
He may ask you to call later as they're in the middle of an industrial move & renovation.
Todd will oblige to any SAU Member; so it's worth joining if you haven't already.
He does compliancing wk too if you're buying from interstate or o'seas.
  • 3 weeks later...
bit hard to call at 11pm.
and i buy cars outside of business hours, which is when they dont work.
i miss REVS.
bring it back stupid government.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
