, still Hopefully one of you guys can help me out,
I'm part way through installing a stereo in my R32, Sony Head Unit, splits in the front, 6X9s in the back, big amp and single big sub. So far I have deadend the doors and boot with Dynamat Superlight.
When I was taking out the existing (crap) 6X9 speakers I noticed that they were bolted to a home made peice of chequer plate. So my first question relates to the parcel shelf. Should I put the (heavy) chequer plate back or fabricate one myself out of MDF board? or could I just put Dynamat on the the car body/parcel shelf, bolt the speakers on and put a fitted mat over the top? How would this effect sound quality?
I've wired everything up apart from the rear speakers and am shitted by alternater whine. The RCA cable runs on the opposite sill to the power cable and it is earthed to the chassis, and it still whines! I spoke to the (not so helpful) staff at jaycar and was sold a "10A DC Noise Reducer", after patching it in there was still a whine. So, any advice? what should I try/do next? I have already plugged AV cables into the RCA ports and played my MP3 player through the stereo without the whine.
Any suggestions would really be appreciated because I don't know much about stereos and am copping shit from the GF for having a crap stereo
https://www.sau.com.au/forums/topic/389464-r32-gtr-stereo-probs-need-advice/
checker plate, why did they use it , holes to big maybe ? photos would help
noise , put a 2 dollar RCA outside the car body and plug into amp from deck, noise gone ? yes, bad RCA or ground loop
dont ground RCA either
keep the reciept for jaycar , you wont need it if you do below.
amp ground must be paint free and decent bolt used. dirty battery teminals or loose can cause noise , a bad /old car battery cant absorb the a/c sinewave ripple from the alterator
rather then rewrite the bilble
read this, david navone has a bible pdf as well but his site is down right now
ten commandments of noise
dynamat the whole rear deck steel top , it makes a big difference. !!! and side panels in the rear sides as well, behind the plastic, front doors as well as a starter
Thanks Carbon 34,
I really appreciate the link, I'll try to determibe where the group loop problem is tomorrow. Alternator whine is a major bitch and I can't wait to get rid of it.
The parcel shelf has been butchered (not a surprise given what the previous owners/morons have done), hopefully the speakers will fit though.
Thanks again.
is the radio a pioneer?
Exactly what i was thinking LOL.
OP - So you "bypassed" the head unit and ran a MP3 player as the source and the noise wasn't there? Is this correct?
If so i would be saying the head unit is rooted.
Bummer, is there a way I can be certain that the head unit is stuffed other than try a different unit?
yes try the rca cable trick I told you to do outside the car , sometimes the shield can be grounded on metal in the dash or loose. but outside the car to the boot it cant hit it. any old working rca can do it or a cheap as chips one.
8ga or 4 ga ground your alterator bracket to the chassis always it helps in every way besides the stereo..... ground at the factory bolt after you clean the paint rust and crust off.
explain your battery age and condition , photos ? where are you pulling power for the deck? does the sony deck have a filter on the power line either one ?
remove your antenna jack and test again, ground loops can be front floated grounds in antennas. are you using a diversity spliter on the antenna? is it soldered and taped or plugged in or freq convertor if so remove it if it has one you dont need it on aus decks .
I want to point something out not to be the dick head to you ... or say told ya so, but this is one of the installers worse nightmares, a boot full of "free" handme downs , and a previously hacked up car. and engine noise
at some point you yank the lot and bench test it on a battery or power supply. we would cringe at it in the first place and bench test everything first to save hairloss
the alternator whine can be your battery in bad condition as before. your battery can filter out noise a fair bit. if its corroded or old it wont ,
does the whine come from sub or which speakers ? deck power or amp powered ones ? what brand of amp. US Audio silver -blue one by chance or sony xplod red and silver one
whine can be induced by rca running past ecu or fan motors
Edited by Carbon 34
nah...
radio is fk'd given its 2nd hand I dare say that the preamp ground plane is popped and that is not helping things.
new radio time. rest is fine by the look of it.
and when someone brings me a mess like that I will simply say this:
as I prefer not to spend 6-8 hours debugging it :)
Hahaha, you're not a dickhead mate you're just honest. I tend to get myself into these situations and if it weren't for guys like yourself i'd be screwed.
The battery is tagged 05/2011 and is topped up with distilled water. The Sony Xplode 52Wx4 deck was in the car when I bought it (couple of months ago) and did not whine with the previous speakers. I don't know if it has a filter and it gets its power from a modified factory loom.
The whine comes from all the speakers, I can't pick up a whine in the bass. The amp is a Cadence 'FX500' 5 channel.
I'll run an RCA cable outside the car when I get one from my other shed, while I'm at it i'll unplug the antena. The antena is just pluuged into the deck and I'm not sure if it has any of the stuff you were talking about.
While I was at Jaycar returning the noise filter I bought some 8Ga cable and will re-earth the alternater, even if this doesn't fix the stereo my car has some electrical gremlins so I'm happy to do it.
Thanks for advice guys
Tell your GF to shutup
Clearly you have been watching too much Dr Phil. Daytime television is bad for you. Bad.
I don't understand either why people do half the things they do to 'modify' their cars, I think the previous owner's favourite pastime was chopping. Cables, hoses, metal panels, whatever, just so long as he needlessly destroyed something a future owner might appreciate his day was complete. Related to this I've finally found some factory BOVs and will replace the atmo BOV from Super Crap Auto that attracts the wrong kind of attention (Bros and Cops).
I re-earthed the alternator this evening with 8ga cable and heard no/little difference. Tomorrow I'll un-plug the antena, do Carbon's RCA cable trick and get very shity if neither resolve the alternator whine.
Will keep y'all posted
how ?
I i barely watch tv actually..
and if a girl had a problem with my car id just say get out simple as that
duno where that came from :/ your to serious
watch this spot mate, I have a test for you but not time to write it now. later today
the ground was to fix other possible issues not to stop engine noise cold
the amp isnt mounted to metal is it
does it run the fronts as well ?
so turn off your car, no noise in system?
whine only when running for sure ? all fans etc off ?
yes, take another car hook it up to yours like your going to jump start yours, dont start yours, just turn the switch on to radio position, do you still have whine? your car is off but the other one is running ?
if yes, its not your alternator ripple so a filter wont fix it
a water battery cant absorb the a/c ripple from the alternator after a year or so , and not legal if your car is boot mounted anyway.
it is possible to test for a/c ripple but it needs a car audio person with the gear knowledge to do it near you , and noise chasing can cost a lot !!!
if you have access to borrow a battery from somone , try it , do you still have whine ? no ? buy new battery, (forgot which car you have but you need a sealed battery in Rear battery setups anyhow for safety , defects)
yes , return battery ,
that leaves your radio and rca as bad items, you said a stand alone ipod worked fine. ? but did you use the same rca in the car or direct to amp with new rca from headphone jack? if you used same rca as in the car now , then yes you have bad radio, or bad radio ground issues , no noise filter on power lines from sony , for under 100 bucks buy a new radio , sony car radios suck in most cases
amp has to have a sanded clean ground with bolt not selftap screw of the same gauge wire as power into amp,
does the noise come from all speakers up front ? or just one side ? one side, swap the rca from side to side, did it follow it to the other side now ? yes , buy better rca and run with care
pull items , bench test all together , dont use bandaid devices , a new deck cost just a bit more and has warranty still.not worth fixing the sony if its bad unless its a top of the line model
hope that helps, the jump start trick will tell you quickly just be sure you know how to jump start a car properly first, not postive to positive , neg to neg, ever, you use the cars grounds on the frame to protect the cars thru the fuses if something goes wrong
Excellent post Carbon!
I'd love to do the jump start trick, I dont have access to another car where I study but when I next visit my folks/shed I'll use my vl to do it. Great idea!
I reckon it must be the RCA cable because I've eliminated most of the other options. I un-plugged the ariel, no change. The battery (in engine bay) is fine , I did the swap trick with my other car's battery yesterday with no change. The deck and amp have good earths (thick wire on sanded back chassis with a fat bolt). The head deck with previous speakers didn't whine so I think the deck isn't the problem. when I connected the ipod to the amp I used another AV cable (2 jacks converging into one) and no whine.
The noise comes from all speakers, I've tried biasing it front-back, left-right etc, the whine didn't change.
When I was at Jaycay this arvo (getting a capacitor for the G-sensor that shitted itself) I explained my stereo predicament and the dude said I could plug in a groundloop isloator right there in the carpark and if it didnt work I didn't have to pay for it. It worked and I bought it. Generally its not my philosophy to use band aid solutions but for $10 the sound quality got much better (fully sick) and it saves me time screwing around with the car instead of enjoying it. When I get another RCA cable (known to be good) from my bro I'll re-wire the stereo and know for sure where the glitch is.
Ah, the joys of cars.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
