pauls Posted January 26, 2012 Share Posted January 26, 2012 (edited) Set of KW variant 3 coil overs for a 2008 Infiniti - skyline v36 sports coupe.Brand new, not installed or used. These are the best coil overs you can buy for this car.Will be selling the car, so decided to not fit them.Get them instantly & for less locally than from overseas. $2,200 firm $2,300+ from overseas with $200+ shipping & import taxes! http://www.andysautosport.com/infiniti/2008_9999_g37/suspension/coilovers/full_coilover_systems/kw_suspension/kwss35285007.html Located in melb. Edited January 26, 2012 by pauls Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/ Share on other sites More sharing options...
pauls Posted January 28, 2012 Author Share Posted January 28, 2012 German quality. These coil overs are the bomb, but hey don't take my word for it. http://www.myg37.com/forums/brakes-and-suspension/185902-kw-variant-3-coilover-g37-install-and-road-test-review-look.html Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6208232 Share on other sites More sharing options...
pauls Posted January 30, 2012 Author Share Posted January 30, 2012 (edited) Yah yah, these coilovers are wunderbar! Edited January 30, 2012 by pauls Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6210290 Share on other sites More sharing options...
pauls Posted February 1, 2012 Author Share Posted February 1, 2012 come on guys, best v36 coil for your coin around! Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6213885 Share on other sites More sharing options...
pauls Posted February 3, 2012 Author Share Posted February 3, 2012 You can do iiiiiit. Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6217696 Share on other sites More sharing options...
aaronjo Posted February 3, 2012 Share Posted February 3, 2012 Pity it's not for a 350Z... Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6217785 Share on other sites More sharing options...
pauls Posted February 4, 2012 Author Share Posted February 4, 2012 As per 370z.com since we are doing the development of the SPC ARms for the G37 and 370z, we noticed that they are nearly Identical. I can confirm they fit 370z and work well BUT difficult to adjust the compression on the fronts once they are on(I suggest an 8 or 9 compression setting on the front along with 9 rebound for starters. I had these on my 350 and they were PERFECT but the the placement of that front compression adjustment is difficult to adjust. Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6218046 Share on other sites More sharing options...
pauls Posted February 7, 2012 Author Share Posted February 7, 2012 State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed. http://www.kw-suspension.com/us/kw_variant_3.php Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6222975 Share on other sites More sharing options...
pauls Posted February 8, 2012 Author Share Posted February 8, 2012 Better corners, smoother ride. Takers? Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6225111 Share on other sites More sharing options...
pauls Posted February 9, 2012 Author Share Posted February 9, 2012 Cheap cheap at $91.60 a kilo Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6226994 Share on other sites More sharing options...
pauls Posted February 11, 2012 Author Share Posted February 11, 2012 Affordable German handling. Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6229536 Share on other sites More sharing options...
pauls Posted February 14, 2012 Author Share Posted February 14, 2012 will FIT SEDAN or COUPE v36 Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6234628 Share on other sites More sharing options...
pauls Posted February 16, 2012 Author Share Posted February 16, 2012 Better ride, no bumps Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6238692 Share on other sites More sharing options...
pauls Posted February 20, 2012 Author Share Posted February 20, 2012 No bumpidy bump bump with these Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6243766 Share on other sites More sharing options...
pauls Posted February 24, 2012 Author Share Posted February 24, 2012 infinity, g37, v36, skyline suspension Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6250139 Share on other sites More sharing options...
pauls Posted February 28, 2012 Author Share Posted February 28, 2012 looks like I may be holding onto these until infiniti releases here?? Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6254830 Share on other sites More sharing options...
pauls Posted March 5, 2012 Author Share Posted March 5, 2012 going going gone? Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6262410 Share on other sites More sharing options...
pauls Posted March 13, 2012 Author Share Posted March 13, 2012 No one after some of the best coils you can get for your v36? Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6273192 Share on other sites More sharing options...
wlin88 Posted March 14, 2012 Share Posted March 14, 2012 one of the best coliover money can buy !! Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6274258 Share on other sites More sharing options...
pauls Posted March 16, 2012 Author Share Posted March 16, 2012 Hopefully these will fit my s14 suspension upgrade in my z31 Link to comment https://www.sau.com.au/forums/topic/389475-v36-kw-variant-3-coil-overs/#findComment-6277689 Share on other sites More sharing options...
