  • 1 month later...
  • Replies 68
Good job
Jump in an earlier group if you can, absolutely nobody will stop you, or even question you. Waiting in line for things is not cool
Don't worry about taping your shoes, or wearing gloves. Totally unnecessary
Good luck
Thanks! Yeah I was thinking boardies and runners should do it... not really into sweat bands/gloves/knee pads etc haha
I'm signed up for the Melbourne one. Saturday 8:00am start.
Had about 3 months away from the gym. Got back into it yesterday and feck am I sore!
Who else is doing it in Melb on Sat?
wear a singlet, sliding around on your stomach on the gravel and ropes will make your 20km experience very uncomfortable
you can always take it off and jam it into your waistband too
If the boys are keen, i'd do it again, going it alone is bullshit
  • 1 month later...
Made it! Pretty sore though...... Really need to work on my cardio if I'm going to hit this again next year.
HEAPS of fun -bit of a drag going solo but glad I stuck it out. Plenty of comradery going around so always someone to help out when a team effort was required.
Tell you what it was a realy eye opener though in terms of fitness. I'm pretty fit in terms of my group of mates but man there were some incredible athletes there... inspiring stuff!
Sounds like you had a good time too? I'm taking this week off from training, going to work on the car for a bit while I recover haha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
