hi guys
i was just wonderin whether or not with the stock BOV on the R33 you can pull the plumb back hose off and make it atmospheric. does this cause any problems??? and does it work better, not better, works the same, just makes a louder noise. what?? can u please email me to tell me, thanks alot.
email is: [email protected]
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/
Godfather - I'm guessing the stalling is for two reasons -
1. runs rich because AFM will read higher than actual air into engine when BOV vents;
2. stock BOV leaks on boost (see thread titled "BOV mod" or something similar...) causing excessively rich.
I have a rice-boy-spec vent to atmosphere - It idles OK, stalls about once a week - After market management will fix that.
lbfalcon - don't know what you are talking about mate... you will not shatter your turbo because there is no airflow back to the turbo. I think you have confused having no BOV, the air feeding back to the turbo through the compressor will have long term damaging effects on the blades and bearings.
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-792405
the stock bov does not leak on boost, it leaks a tiny little bit of air around 0 pressure to make the transition on and off boost smoother.
The BOV mod is nothing special it does nothing for power. I tried it and I must say leaving it alone is the best idea.
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-793141
Ronin - i think i know what ure referring too... seems familiar.. something abt placing a small screw on one of the small holes at the bottom of the bov.. will look it up
Don't use a screw, use the little black lid bit out of the top of an old style BIC Biro. Does the same job, fits the hole like it's made for it, and can be removed without having buggered up the OEM BOV :D
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-795152
I wonder if a stock bov with the screw mod vented to atmo would idle better seeing as it wouldnt be leaking and causing afr probs?? Just a thaught..
I know a completly stock one will contiuously stall when vented to atmo.
My stokies got the little mod might vent it to atmo and see how it goes just for curiositys sake, however i dont know why youde want it venting to atmo considering all the negative sides to it, and if your into the noise the stockie bov plumbed is pretty loud when youve got a pod filter, well mine is anyway.
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-796593
In my case it made my idle rougher and caused minor surges, but this was plumbed back...
I originally had an older style Turbosmart Type II BOV which caused a rough idle and surging.
I went back to the factory BOV and the rough idle and surging went away completely, however as already mentioned it just wasnt as snappy.
So I did the screw mod, there was a noticable difference, but it idled a little rough and was surging again but not as bad.
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-797077
the screw won't help your cause with it venting to atmo, that little hole just does exactly what rev210 says, smoothes out the transition from off-on boost. blocking it just stops that from smoothing out.
Ok, wouldn't that little leak be just like if you had a leak in your manifold (when the stock bov is venting to atmo of course) and a leak in your manifold would cause rough/no ide wouldn't it?
I just recon this little leak is why the stock bov doesnt idle when vented to atmo and most other aftermarket ones do because they dont have that little leak.
Dont get me wrong im all for the stockie being plumbed back and dont know why anyone would want it venting to atmo. My mate tried to tell me once that venting to atmo was better cause the hot already compressed air went back infront of the turbo again with a plumb back, i dont recon this is really true cause when air drops in pressure it drops in temp aswell so theoretically it would go back at the same temp as it came in, accept of course that the intercooler has already taken some heat out so maybe the air would go back at a lower temp than it came in? would this make plumbacks better??
Also i can see some good in blocking off the hole, yes it may stop the smoothing out as may people have said thats why nissan put it there but surly the turbo would not be working as hard to make the same boost?
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-797227
How does air leak at zero pressure?? i always thaught you needed a difference in pressure to get movment. anyhow i know for a fact it does leak under pressure cause i blew on it and like alot of other peolpe found out when they tried this it bypassed air (leaked), aparrently a human being can generate almost 2 psi with there mouth i found the harder i blew the more it leaked. this would mean it leaks under pressure wouldnt it?
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-797278
  • 1 month later...
I can say that yes the stock bov vents on spool when I had it venting to atmosphere, I rigged up a really dodgy bent piece of metal which then bent out to vent the air, but I found that having something blocking it almost stopped the stalling on idle, I found this out by holding my hand over where the air vents and it idled smooth as silk, once I unblocked it, BAM rough idle?
I have no friggin idea what this means and am not a mechanic, I will be taking pics later on before I reattach the plumb back just to prove how DODGY it was :(, sick of just before boost hearing a constant whoosh from the bov and thinking of all that power being lost :D
https://www.sau.com.au/forums/topic/39036-stock-r33-bov/#findComment-886353
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
