R&R is just a section of the load map, if you are running extra boost, big exhaust, FMIC etc you will always hit it with the stock ecu if it hasn't been tuned.
Basically anything that improves performance/airflow over stock.
car came with FMIC + 3in turbo bk + cat, and I only added a 10psi R32 actuator.... and apparently R33 ecu cannot be tuned? could that be the cause of all my probs, the shitty stock ECU spitting dummies???
thanks again
imo it is almost certainly your problem, just rich, bad spark = misfire because it is running rich as hell.
though it probably has a whole host of other issues like air leaks, old dying sensors etc like every other shit bucket skyline on the road, they are old cars and stuff is starting to break en masse on them if they haven't been meticulously mantained.
Sounds like you better take it to a performance shop as it doesn't sound like you can do any work yourself bar change a tyre... so if you can't do it yourself then they are going to have to do it anyway. Might as well get them to figure it out.
A failing fuel pump will cause a lean condition though???
Shit balls f**k lol, I meant you can tell the difference between a failing fuel pump/lean pop and misfire. If he doesn't have lean popping issues, he MIGHT not have a failing fuel pump. If it was well and truly failing though, he most certainly would. He would have starting issues too. Even holding revs on idle will cause it to lean pop.
- I hear ya :P but all cars are old, just imports take more of a beating running turbos from factory!
okay tell me this, what would be done to rectify a R&R or rich situation (providing it is R&R bad spark) is there a definitive answer if the dyno guy sees it running super rich???
if you dont mind giving me a lesson on cars :P cheers (from memory the O2 sensor was changed - that didnt make much difference, the rest I have no clue, only had the car 5-6months)
You retune it, either convert to an R32 ecu and go a nistune (looks stock and won't get picked up if you get defected) or you go an aftermarket ecu and retune.
About a $1000-1500 adventure to do properly if you are paying for 100% of the work to be done.
Edited by Rolls
OKAY - so theres no other way to fix? otherwise I cant drive the car until I can get the money for the nistune setup (since the r33 ecu cant be tuned?) I always wanted a nistune as its better long term :D just thought there would be a way to fix this issue for now?
OR - can i go the SAFC 2 direction for now? will that cure it? or do i still need someone to tune the SAFC?? because they are cheaper again?? just for a while so i can actually drive
dont waste your money on a bandaid solution.
For the time being turn the boost down by putting the old R33 actuator back in instead of the r32 actuator, that will drop your boost from the 12 odd psi you are getting at the moment to ~6-8psi which will stop it spluttering at peak torque.
It won't magically fix your other problems though, this is assuming the problem is the ECU is making it run rich as f**k and getting the typical rich misfire. It could be something entirely different.
Just take it to a shop and throw money at it, as it doesn't sound like you are able to do any work yourself anyway.
Edited by Rolls
okay will do they dyno monday and see, but Id say you are probably right :P hopefully the dyno will show other issues too,
then I will drive it nicely on standard boost which i think is 5psi at low rpm to 7psi at high... until I can buy NISTUNE? would you say NISTUNE? or PFC? I like nistune, I am only aiming for 200rwkw for a while, then maybe one day 250, but its just a streeter not track - not my thing :)
thanks again for ur advice/help!!
well thanks again (IVE OPTED TO SEE FOURS N MORE, SPOKE ON THE PHONE AND HE SOUNDED LIKE HE KNEW A FAIR BIT, so fingers crossed! talk MONDAY :P)
Note OP has an auto. Does the R33 have the auto ecu in the main ecu like the S1 stagea? In which case the R32 or Z32 ecu +Nistune will not work? Looks like a job for an E-manage!
Yeah I think they do, there isn't a separate ECU. Even a power FC wouldn't work in there.
Sorry? Can I use Z32 + nistune board?
it seems silly that a company so big cant make a board to run r33 or auto r33.... can anyone give specifics or I will just contact them myself :P
Nistune is not a big company its a small group of hard working people. By all means contact them yourself - have a read of their website
http://www.nistune.com/faq.php
You need to start looking for a Greddy E-Manage (or an HKS F-Con although tuners for them are few and far between).
There are only 2 people who work at nistune lol, and both of them have full time jobs it is just something they do on the side for a hobby.
Just got an email from Matt at nistune, and he says the Z32 ecu will run my car and the auto in my car, he will supply z32, fitted with Nistune and base maps :D excellent! THEN i look for a tuner. BUT my question is nistune with base maps for rb25det, can i drive it on the new ecu nistune setup till i get tune? or just get the tune done asap as people say its around $400 for a tune, and is it possible Nistune with a tune could fix all my problems, or is it still AFM related? cheers. I will be getting nistune done asap!!!
thanks guys will do dyno monday let ya know
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
