I scratched one of my Buddy Club P1 IIs... stupid, stupid, stupid.
Thankfully it is only the outer polished rim.
I'd like to get the rim re-polished, so it is purrdy again :headspin:
Who knows of where this can be re-polished, and at what cost?
Preferably drop off on saturday - I'm full time and don't get a chance during the week.
I live in the inner east, so anywhere round there would be good.
Thanks lads (and ladies)
Marcus... just jump on the group buy.
proabably pick up one rim cheaper :)
seriously. There is a dude here near me.
he did the noofline's wheels (dj_lethal)
came up great but he doesnt do it overnight. It does take time.
PM him for more details.
SLY, i told you about it ages ago
I had my scratched rims fixed at Advanced Alloy Wheel repairs and they had heaps of wheels there they were repairing - looked professional and did a really good job on mine, but I think it depends on the finish of your particular wheel.
Give them a call and ask, number is 9555 1333
or check out http://www.advancedalloys.com.au/
more info: just remembered that when I was asking around about my wheels, the only thing that the guy at advanced alloys (and everywhere else I called) said was that if your wheels are shadow chrome finish, it can be fixed but is a lot harder to get the finish and only 1 place in vic does it - they all send their wheels there apparently.
Anyway, it's more expensive but can still be done (talking around $200-$250'ish per wheel instead of $100'ish normally)
proabably pick up one rim cheaper  :cheers:
Real funny Ash hahah thanks :usuck: jk
Thanks, I'll PM.
Black33 thanks I'll give them a call...
I'm going to call my wheel shop today and see who they use
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
