congrats it looks like you baught a 34 gtr.
you can fit 10.5 inside your guards. it depends if you like concave. 18s have concave. 19s have more dish and straighter spokes. search around the net youl find diff wheels
I have 19x10.5 +22 sl's on my BNR34 with 275/30 tyres
Great fittment, only very light scrubbing on full lock on uneven ground (just avoid full lock where I can)
Any further info just let me know,
Cheers,
Anthony
Heres some pics of mine, i know i had alot of trouble picking mine due to not wanting excessive scrubbing but still filling the guards and getting a flush finish. probably would rather +15 than +22 like mine, but i couldnt pass up matte black ones as i believe there not easy to get a hold of.
Hope that helps.
Cheers,
Anthony
Thanks Anthony, so yours are +22? Why rather +15? Yours look fine. I didn't realise the SL's come in 18" +22
Yea mine are +22 but are 19", not sure if they are abit different becasue they made a small run of matte black ones?.. they came from OTR and they also had a 19x10.5 +12 set that sold before i bought my car, i would have picked +15 just because its slightly more aggressive, but at the same time may have been slightly less user friendly than +22. in the end its only 7mm, and i am very happy with the +22, looks really good imo.
Cheers,
Anthony
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
