speak to my mate at oversea(another r33 GTR owner) about sold my car and looking for a new car. He show me this one. The car belongs to his friend.
Sure i can't afford it, but it's so damn hot and i think it's good to share with everybody.
1999 built, frist rego at 2000
the paint u see is factory color
Apexi power FC
Kei Office Suspension
RSR Exhaust (5 months old)
HKS twin plate clutch ( 4 months old)
Blitz Blow off walve
Blitz Intercooler
HKS Oil cooler
Short shift
Nismo Dash board
Nismo Wheels
Trust Boost Controller
Blitz boost gauge
brand new alarm system
Alplne amp with Rockford Speakers + Sub woofer
and much more
This sale also comes with the following:
1 set Tein Suspension
1 set GTR Original Suspension
HKS Hyper Exhaust
Original GTR Exhaust
Original CPU
Original side mirrors
Spare alternator
Original HID 4000k coz now fit with 6000K
if anyone happy to pay $13,4999 for it i am sure i will help him to bring it into aust :)
https://www.sau.com.au/forums/topic/39059-2000-r34-gtr-v-spec-for-sale/
this is not a real For sale thread, just too boring...
the rim is LM GT4 special edition, the most expensive nismo rims
is that a V spec as well?
but i can tell u this car is a lot cheaper than 105K, i COPY the 135k price from someone :)
theres an R34 GTR for sale in sydney on parramatta rd its similar to that one its got the factory chameleon paint, ganador mirrors but different rims
selling for $105K
Saw that one too. He was asking more than $105k when I saw it. Was a very nice car though :cheers:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
