I am contemplating getting a pre-purchase inspection done on a car that I am looking at purchasing and need a recommendation on who would be very good in this regard.
The inspection needs to be comprehensive with mechanical tests including compression/leakdown tests, cooling system pressure test, paint, prior accident damage, revs check etc with a comprehensive written report prepared including photos.
I am an interstate potential buyer. The test could be done onsite or car taken to a workshop. They need to know the GTRs or imports in general pretty well though. Perth area say within 30-40km.
Any help much appreciated.
http://www.a1autocheck.com.au/inspections/inspection-descriptions
with Paint depth analysis. Being mobile is handy. Did my BMW and did a great job. I would look at doing that, and a workshop to check out the engine/trouble spots.
Yet to see a workshop do a great write up.
http://www.a1autoche...on-descriptions
I had the same reservations about a workshop doing a very good written condition report as it just does not happen in my experience.
A1 don't do compression tests so may have to get that done by one of the workshops recommended here, but he may have an idea by listening to the engine etc.
Would this guy be OK in checking a GTR out, he's probably used to checking many more modern cars.
Thanks.
Consolidated workshop thread...
Else Hyperdrive gets my vote
Yeah, saw that thread but wanted peoples more recent experiences and given I want electrical, paint etc also checked at the same time. I will look into Hyperdrive.
C-Red
All Star Garage
X-Speed
Hyperdrive
Those are, in no particular order some of the bigger names in the Perth import scene.
Which couple would you lean to more for a R32 GTR and who have had probably more experience in the industry to give me an overall informed opinion, which covers all general areas mechanical, electrical, body etc.?
I had 3 x R32 GTR inspected at All Star Garage and 1 x R34 GTR inspected at C-Red. The reports given to me were just written on a piece of lined paper and highlighted the problems with the car. Compression and leakdown tests were done as well. Written 'report' was pretty average but did re approach the mechanics who actually did the reports and had a good chat afterwards. Ant (X-Speed), Sean (All Star) and Marc (C-Red) all know their GTR's in my opinion.
Find out which workshop the owner takes his car to and make sure you choose a different one!! Getting a workshop to do a 3rd party inspection on their own car is kinda pointless...
Thanks.
Hence I recommended getting a shop to check the motor and normal GTR trouble spots :)
The newer the car the more of a pain to check IMO, and he was fine with my BMW, as I mentioned.
As there isn't any "Stateroads" over here, he is your best bet for paint depth, and the rest. Check a sample.
Thanks all for your replies, very informative.
I will now choose wisely based on above advice.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
