All I was saying was that with that terminal speed, and the right setup and launch, your car is capable of high 11s :mad:
True... but your talking nitto or slicks then for a high 11 i reckons.
Good time indeed SLY33, i started dragging last year and you pick it up pretty quickly IMO
After 2-3 meets your heaps better than your 1st thats for sure.
I ran flat 13's... with a lucky 12.9 @ 109mph.... 2.1 60ft.
And that was after a few meets.
My first times were around 13.8... so my times dropped quickly as yours will.
Just get out there more. It becomes addictive thats for sure.
  • Replies 45
I'm addicted but I just can't get the times :mad:
I've had around 20 passes and improved 0.2sec even after about $1000 of mods :rofl: :rofl:
I'll be back out there again tho in a month to chase that 13.6sec which I believe my car is capable of (just not the driver) :wassup:
I went from a 14.8 at 98mph to a 14.0 at 100mph with just improving my launches.
I got the drag bug to, but this coming wednesday is the last wednesday street meet till next summer :D For some reason they are changing to every second saturday 11am-5pm for off street drags during winter! :throwup:
So i reckon i will be back out next week trying to improve, just with practice.
Straight from the www.wsid.com.au website
Winter Street Meet Mode
WSID will be switching to winter off-street mode for its Auto One Street Meets, presented by Pennzoil, from the beginning of May.
Through the months of May, June, July and August the off-street events will move from Wednesday nights to every second Saturday.
This will see off-street events being run on:
May 8
May 22
June 12
June 26
July 10
July 24
August 7 and
August 21.
These race events will see gates open at 9 am with cars going down the track from 11 am to 5 pm. Due to the increased hours of operation the entry numbers will be extended. Once we’re back in the warmer months in September the Auto One off Street meets, brought to you by Pennzoil, will switch back to every Wednesday night.
I AM NOT HAPPY! :dump:
I think their will be more spectators and more drivers but having more drivers is a very bad idea unless they break it up into groups (ie; groups of 50 at a time, do 5 runs each and then park it for the day).
At the moment with 120 cars on a wednesday nite it takes 3hrs to get 3 runs and then 2 runs in the last hour. Thats way too long to wait inbetween runs (both for comfort of the drivers and the cars). If WSID break it up into say 4x 50 car grps it means those 50 can get it over and done with in a fairly quick time period and then be done with things.
I started in the 13's and worked my way down to 11.7 before I had a problem with a ringland hahaha, I'll be back in a few months, I hope everyones still racing then as at some meets last year I was near the only R33
I don't think you need to worry about competition sir! The numbers have been growing fairly quickly, as opposed to track days where there's a meeting once a month with the drags it's (or was) once a week.
Changing to the Summer timetable has less to do with temperature (ambient and track) and more to do with the fact that the track gets quite dewey in the early evening in the Winter months. Very slippery...
Adrian
hahahaha its not the competition, it was lonely out there rofl
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
