hey guys im looking at getting a internal waste gate for my gt3076 as its a external gate model and im selling the rear housing and buyin a internal wastegate one
just wondering if anyone has seen or played with this internal wastegate seems to look pretty nice with the extra springs to go inside for desired boost levels
http://www.ebay.com.au/itm/Kinugawa-Adjustable-Turbo-Wastegate-Actuator-Garrett-GT3071R-A-R50-3-Spring-/270912634695?pt=AU_Car_Parts_Accessories&hash=item3f13a6bf47
just wondering how it would hold up boost as ive been told to get the 14psi garrett actuator but this one is a bit cheaper just wondering if it might work the same
Thanks guys
https://www.sau.com.au/forums/topic/391896-kinugawa-wastegate-actuator/
oh really are they the same as this one
any suggestions im goin internal gate for now just cause i bought a dump pipe and everything to suit off another member
i was looking for a actuator with a minimum of 14psi :) so hopefully theres no boost spike issues and im not sure if the rear housing im buying comes with the brackets and everything
I'm not turbo expert but I'm guessing Garret will give you the quality needed that 100 bucks could save thousands. Call gcg up I'm sure they will have one to suite
Edited by Bsa
yeah ill get the part number off them and get it from garrett direct cut out the middle man hahaha
hey just wondering i bought the mafia's dump pipe he had on his car with the gt3076 later down the track would it be able to weld the stock internal gate closed and weld a external to the manifold or is there no point as im only wanting to achieve 280-300 :) on bp98 thanks dude
ive seen a fair few results on here with the 56t .82 on 17-19psi internal gate make 280-300
the mafia made 315rwkw
i cbf getting a new dump pipe made up as im buying everything so its only a day job to put it all together
i was considering external gate but ive seen results pretty much the same using internal vs external with the .82 rear
when it comes to the .63 external for sure
I went in Mick_o's 33 with the .82 internal gate GTX3071 and can say the Garrett actuator does its job well.
The car was rapid and had really good boost recovery. I wouldnt think twice about going Garrett if its an option for you.
Blake I think the reported Kando issues are more around the housings than they are the actuators. Ive used a few of their actuators now and they work fine :thumbsup:
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
