Located in Boronia (SE Melb), happy to freight at your expense
Complete GTR for wrecking minus the following:
- Wheels
- Complete Motor & Gearbox
- Exhaust
- Brakes
- Front Hubs
- Front Seats
- Fuel Tank & Pump
- Steering Wheel
- Radiator
- Steering Rack
- Driveshafts
- Dash Surround
Here's a start:
- Diff - $400
- Rear Driveshafts - $200 pair
- Rear Hubs - $200 pair
- Rear Subframe - $200
- Tailshaft - $200
- ATESSA 4WD PUMP - $200
- Space Saver - $100
- Boot Lid with Wing - $400
- Rear Bar Skin - $200
- Rear Reo - $150
- Tail lights - $200 pair
- Rear Garnish - $150
- Boot trim - $200
- Sideskirts - $400 pair
- Rear window - $250
- Rear 1/4 Glass - $150 each
- Front Glass - $150
- Door - $250 each
- Door Trims - $150 each
- Mirrors - $150 each
- Electric Window Motors - $150 each
- Glass front doors - $150 each
- Driver Electric Window Switch - $100
- Passanger Electric Window Switch - $50
- 180km instrument cluster - $250
- Centre Console Gauge's (3) - $200
- Complete Set of Locks + 2 x GTR KEYS - $250
- Floor mats (5) - $150
- Rear Seats - $350
- Dash - $250
- Centre Console - $200
- Rear 1/4 Trims - $150 each
- Carpet - $200
- Seat Belts - $50 each
- A Pillar Trims - $50 each
- Roof Lining - $150
- Standard GTR struts $250 set
- Standard Front Swaybar - $50
- Standard Rear Swaybar - $100
- Standard upper arms - $150 pair
- Standard uprights - $150 pair
- Standard lower control arms - $150 pair
- Standard castor rods - $50 pair
- Front Crossmember - $250
- Front Guard Lining - $250 pair
- Series 3 Brake Air Ducts - $250 pair
- Air Con Condensor - $150
- Air Con Compressor - $150
- Air Con Drier - $50
- Air Con Lines - $150
- Standard Intercooler - $350
- ABS Unit - $350
- Intercooler Piping - $250
- Standard BOV's - $250
- Standard Washer Bottle - $50
- Overflow Bottle - $50
- Heater Core - $150
- Front Strut Brace - $150
- Rear Strut Brace - $150
- Front grille - $250
- Damaged Bonnet - $350
- Damaged Driver Side Guard - $200
- Damaged Driver Side Guard Raiser - $100
- Passanger Side Guard - $300
- Passanger Side Guard Raiser - $150
- Standard Side Indicators - $50 pair
If there's anything i've missed just shoot me a PM.
Chris.
  • Replies 190
You wouldn't have the two front lights in descent condition, would you?
i wish! there's a few bits i've kept from the driver side headlight, the passanger side which u can see in the pic is repairable but it's cracked all the way through and right around, mostly good for parts thats about it.
if anyone wants a pic of the RHS headlight PM me your mobile number i'll mms it to you
Two PM's from me.
working through the pm's now you'll have response soon
Selling that front mount?
not that one, but i have a standard one if your interested
Airbox and snorkel? Pm me
nope,,
Does the k-frame look bent? I might be keen plus any front control arms and knuckles that look ok. I dom't need the brakes
the k frame shifted on its mounts a mm or 1/2, i wouldn't say its bent though. the nismo lower control arms im keeping, i have standard arms from another car if you like, hubs are gone, brakes im using.
what do you mean by knuckles? thats the hub and knuckle, have a look in the pictures, i have standard uprights for sale, and standard upper arms
Oil cooler assy?
sorry i thought i got everything but obviously not, the oil coolers not for sale.
i bought the car below, so i have 2 of everything, minus motor and gearbox and go-fast bits, so mostly all stock parts.
http://www.skylinesaustralia.com/forums/topic/327477-33-gtr-skylinegenuine-vspec-less-topend-clutch-calipers-10900/page__hl__r33+gtr+shell
Just PM.
hey, replied to all,
Hey mate, do you have a list of what you got left off of the silver GTR?
the silver GTR was missing alot of parts, and a lot of parts which were stock have been replaced with aftermarket.
i dont have any aftermarket parts for sald, mostly an entire standard car worth of parts minus engine, gbxox, and brakes.
if anything in particular you are after shoot me a PM
Mate rear sub frame in what condition is it.
I'm chasing one and must be straight and no rust.
Only need the frame, no arms etc.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
