Hi all. Bit of a newbie here. Been signed up for a while but only now joining the skyline clan.
I have my dream r33 gts-t patiently waiting on the docks in japan at the moment and can't wait to tackle compliance and rego once it lands here.
One small thing that it is missing though is a set of the geniune nissan floor mats. I have posted in the wanted section and searched in the for sale thread but can't seem to find any. Does anyone have any that they want to sell or know where i can get a set for a respectable price (ie. less than $200 that Just Jap quoted me).
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/39243-greetings-and-floor-mats/
hey strydes and WELCOME 2 the Skyline FAMILY :mad:
i also try to get some floor mats when i 1st got my skyline, i was quote $400 for Real NISMO Mats (may have been less cant remember now) but $200 was the cheapest i also got for just nissan mats, hope u find a better price as $200 is abit of a rip off
mike :rofl:
ive got two sets of floor mats with my car
One dark grey ...... light grey edging .... red skyline badge ... orignally came out of my R33 i think ive seen them in R32's. Currently under my bed - my cat likes sleeping on them :)
Other set came out of car yard Skyline which i have in my car now cos they look tidier than my other pair ...... the white mottled puke look you guys are talking about ..... although i think that will go nicer if i ever decide to go chequer plate.
The woven checkerboard is the pick of the bunch in my view, these are the ones with the metal plate on the two front ones and the centre back which says 'GENUINE SKYLINE'
mmmmm. very nice.
These, therefore, are the ones i am looking for. However, if anyone has the other ones that they would like to get rid of i would certainly be interested. Nizmo maybe??
dan_the_man, do you want to sell or are you just teasing me??? PM if you do want to sell.
the series two are mine! *thinks they look nice wit ricey chequer plate*
but if you really want the series ones i have i may be tempted to give them up...... but also i'll be giving away a part of my cars history as they came with my car :) *why i havent sold them before*
Thanks all for your responses, however, I have managed to pick up a set from a fella in brisbane. Ended up paying $75 for future reference if anyone is interested in the going rate.
Now all i need is a car to put em in... :boinkcar:
Once i do, i look forward to seeing you all on one of the cruises.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
