G'day guys I need 2 bends put into 38mm seamless chromoly pipe asap. Somewhere in Melbourne where I can drop off and pick up after hours. And I need it done by Thursday at the latest. Cash waiting
Cheers in advance - Trent
https://www.sau.com.au/forums/topic/392485-help-bending-pipe-needed/
U-neek bending in Dandenong south have done seamless chromoly for me before, not cheap though for small quantities. They use hydraulic pressure in their mandrel process from what I understand. Worth a call anyway. How thin is the wall?
http://www.uneek.com.au/
38x6mm tube for a rollcage!!!
Obviously it's not a regular automotive cage??
CDS 38x2.6 350mpa is a minimum requirement for everything other than hoops.
CAMS are about to release a minimum requirement for 4130 and T6 materials for certified cage manufacturers (CDS / CDW anyone can fabricate rules will remain apparently)
I can tell you it's not 38x6mm as a min requirement though.
Sure it's not 38x3mm?? (6mm total wall)??
I know alot of suppliers, performance metals, race tech and myself were nil stock of anything under 3mm wall 4130 late last year. The only available sensible size was 44 & 38x3mm.
It was just a guess guys the pipe is at a workshop so I couldn't measure the wall, 6mm was stuck in my head but I think thats the thickness of the plates I'm using.
My father in law organized the pipe and as far as I'm aware it is to cams spec.
Anyways we ended up making one out of old tube we had laying around (vic drift is not cams monitored i just wanted to make it to spec just incase that ever changes) and I will tackle the chromoly at a later date,
Cheers - trent
Edited by TJR32GTS-T
For the application I need it for my slap together cage will do. When It comes to building a cams one it won't be "slapped together"
Im not having a crack. the person building my next cage has built cams cages before at previous jobs I was just trying to find somewhere to get the pipe bent :)
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
