Just quick question when someone like me (new to the turbo scene)
Buys a stock gts-t what would be the best way to get more power out of it for around 10K like I know the standard stuff but what is a nice lil unit turbo wise that seems to have a all round quality to it?
other than that it's inter cooler bigger injectors and after market ecu that will give you the gain yeah? And is it worth just getting the internals of the stock turbo upgraded to ball bearing?
Thanks for your time guys hopefully one day I can actually join in a turbo debate and know wtf is being said :mad: lol
ignorence is not bliss lol :rofl:
Cheers.
https://www.sau.com.au/forums/topic/39254-has-this-question-already-been-asked/
i would say with 10k
I/C (possible gtr cooler or hybird)
ECU (wolf3d, powerfc, depending on power lvl u might be able to get a chip ecu or a safcII)
Rebuild would be also a good idea again depending on how high you want to go (r33 with sotck internals made 411rwhp)
HKS GT25 - i would say would be a good turbo not 2 laggy and should give you somewhere around 300+ if u want 400 to 500 then you will be a gt30
mike hope this helps :mad:
cheers mike that's what I thought yeah I was just hoping for something average so had the power when I wanted to play. so around the 220/250rwkw maybe?
But that advice is great thanks
Thanks squizz well for 10K if I gave you the car and you brought back a weapon the hell take it lol but wait till I get the money lol oh and the car lmao 2 months :mad: Just doing my home work for now :rofl:
2 npz arian :mad:
If i was in your shoes i would do rebuild, Forget piston,cam, cam gears, strenght rods. Then ecu and gtr cooler (gtr coolers r good for alest 600hp), and if there was money left over a hks gt20 or some sort of turbo rate at about 400hp
Best thing you can do is forget all the advice you just got except the bit about reading the stickies they are where you do your research. The stock R33 turbo is ball bearing. Before you start building it's best to know what you are building on,
ps oh!... and especially don't give your car and $10K to Squizz........give it to me............or maybe just the $10K :wassup:
1. panel filter with cold air induction ~$200
2. Custom m.s 3" turbo back exhaust ~$1100 fitted
3. Hybrid FMIC with piping ~$1200 fitted
4. Bosch 500hp Pump ~$400
5. Injectors ~$750
6. Electronic Boost Controller - AVCR ~$600
7. New ECU PowerFC with hand controller, Tuned ~$2000
8. New Turbo ~$2500
9. Suspension Mods - King Springs with Bilstein shocks - ~$1500
10. Brake Upgrade - DBA Slotted rotors with good pads ~$1200
That goes a bit over the $10 000 budget to around $11 500. Probably allow for about $12 000 to have an all round, reliable, quick street car. I think 220-230kw atw is achievable.
Depends if you want to do some mods yourself too. Tuning will cost a abit depending on what order you do the mods in or if you do them all at once :headspin:
Guest INASNT
pointless getting boost controller and power fc, might as well get a wolf3d with built in boost controll
No once again u have given wrong info.
Power fc and boost controller is fair superior to a wolf 3d.
Also u wouldnt waste time building a strong engine with forged internals then chucking on a pissy 400hp turbo.
ARIAN
For $15,000 u can get 300rwkw without having everything maxed out like stock fuel injectors etc.
nice I was only after 220-250 rwkw for a everyday driver that has the poke to get up and dance on the weekend. But 300rwkw is a nice round number.
Cheers to all so far this is good info I know the sticky threads cover most this but I just wanted a quick simple list of engine mods with out sorting through all the non importaint stuff :(
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
