Just wondering if someone can tell me for certain if an R34 GTR airbag steering wheel can be fitted to a R33 GTR series 2. I have been told that it 'should' a series 2/3 R33 GTR but won't fit a series 1. I think they are a better wheel and have found one, but I don't want to fork out the cash until I know for sure it can be fitted successfully. The wheel is located interstate so there is know way of doing a trial fitting. Does anyone know if this can be done, or has anyone done this themselves??
Cheers
they will fit
Do you know this for a fact? And even if the do actually fit, will the airbag still operate? I have heard that the R34 has a separate airbag computer that is not compatible with the R33 even if the wheel physically fits OK. I spent weeks and spoke to several experts (Nissan dealers, importers, performance gurus specialising in imports, and crash repairers) in order to answer this question about a year ago without success.
PS. MAXX, I hope you are right. But please ensure you are positive, and not just offering opinion as it may send someone (like myself) on a very expensive wild goose chase.
Cheers.
Mmmmm, it seems very hard to get a positive answer. Here is a small pic of a R34 steering wheel.
http://www.skylinesaustralia.com/forums/at...achmentid=14588
Has anyone actually tried it? Like Garage Menace I am finding it difficult to get a definate answer, and don't want to fork out the money if it won't work. It would be a nice replacement if it works.
i wanna put one on my s2 r33 gtst, but havent got the $$ for one yet, instead bought r34 vspec seats to go in
but yeah id imagine it would work at it would just have a plug and a motor or whateva inside the wheel
the ecu would do the rest of the work then
who wants to crash one n find out? :( j/k
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
