Hi all,
I am going for a drive tonight as my 33 will be picked up tomorrow. I am very sad that it's going but I need to take it for one last drive. I'll be at Krispy Kreme tonight around 845 if anybody is interested. Will be going on a nice little drive and taking some pictures. Would love it if some skylines are there..
I would like to say also that this club is the best club/forum I have been a part of with all it's members always willing to help people out.. So thank you to the people that run the show and to all the members..
Keep up the good work and hopefully I'll be back in a skyline
Cheers
https://www.sau.com.au/forums/topic/392829-last-cruise-for-me-and-my-baby/
My bad orange grove..
I'm still going to hang around on the forum and read and learn more .. It's just going to make me miss my skyline.. Hahaha
I just wanted to thank everybody for being cool and all the moderators for creating such a great community
Yeah defiantly don't need a skyline to be part of SAU , imo SAU is a very nice community that is very helpful compared to the other forums i have been around lately
"EVO OZ" ..... those guys are so uptight lol
Edit : it is sad to see the skyline go when my went felt like i lost a testicle LOL :domokun:
Edited by Longz
not jealous, just have a life :nyaanyaa:
dont be jealous....
jokes, jokes.
or srs? :ermm:
What makes you think I don't..
You've must not of heard of this thing called multi-tasking.. It's ok, it's a woman thing :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
