Selling used PowerFC for R34 GTR. Pictures will be up later tonight when i get the chance to grab some.
Located in Sydney, would prefer pickup but will ship if needed. Price is $650 negotiable will do it cheaper if you come pick it up
Cheers
Edited by god34r
https://www.sau.com.au/forums/topic/393085-r34-gtr-powerfc/
  • 4 months later...
