After finishing my annual shed clean up, I have come across a large number of various parts and accessories which I do not require and will not use. Everything is in good condition and was in full working order at the time of removal from the cars. For more information regarding the various parts, please contact me.
R33 Complete passenger side door - $90
R33 Carpet - $50
R33 Dash - $50
R33 Rear lights - $60
R33 Rear Window - $80
R33 Steering column & Boss - $100
R33 Door Cards (2 front, 2 rear trim) -$25ea
R33 Sub Frame & Rack - $150
R33 Nissan stainless steel cat back exhaust- $150
R33 Side skirts Japenese made - $20
R33 Front uprights & hubs - $50
R33 Side Windows - $25
R33 Rear Hicas - $20
RB25DET ECU - $100
S13 Exforce dat back exhaust system &de-cat pipe - $300
GTR Alloy Trust filters - $60
GTR Alloy rear hubs - $100
GTR front uprights & hubs - $200
GTR Air flow meter - $80
RB20 Air flow meter - $30
Z32 Air flow meter & Trust Filters -$350
AVS Wheels with brand new tires - $1000
Tial 44mm Gate (Brand New) - $350
Cusco Bonnet pins (2 available) - $50 ea
Trust 3.75mm Resinator Pipe - $50
Supra Project Mu pads (front & rear) -$200
RB20 & RB25 Cam covers (2 RB20 & 2RB25 sets available) - $40each
SR Coil covers (3 available) - $5 ea
GTiR Head Stud Kit - $100
Cusco WRX GC8 rad plate - $50
SR Cranks STD size (3 available) - $300ea
STD SR16VE crank STD size - $100
Strut Braces Front GC8 GAB - $50
Strut Braces Front R33 Apexi alloy brace -$50
Strut Braces Rear R33 genuine Nissan brace- $50
Some parts can be posted, others are pick up only. Please contact me to confirm for the part you are interested in.
https://www.sau.com.au/forums/topic/393176-parts-accessories-for-sale/
hey, ill take the Strut Braces Front R33 Apexi alloy brace -$50 if its r33 gtst?.. loox nice, and i so need one .. i can do pickup. im on the gold coast.. thanx
hey mate, if your willing to separate the z32 AFM's ill take one, dont suppose you got the plugs?
cheers
I'll split with you, I'm interested in the other then - do they come with the plugs?
Sent a PM about the rear strut brace earlier.
Cheers.
I have ur brace in bris now the AFMs are brand new one has a cracked corner and mesh on the bottom has a little dint no air filters they are $150 ea who ever pays first gets the one thats perfect but they are both new I have tomei plugs brand new if you want one $40 each
I have no Idea what part you are talking about are you asking about the trust filter and the alloy pipe which connects to the GTR air flow meter? If u are they come as a pair.
postage to Vic for strut brace?
Sorry i had the wrong guy you wanted nissan rear strut brace & Delivery $70 guessing the afm is to much for ur budget?
  • 2 years later...
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
