Morning People,
Throw me offers need this stuff gone..!
Will seperate...
I upgraded to aftermarket stuff so these things were all in good working order and only removed yesturday...
I have for sale a complete inlet manifold, trottle body, idel ACC motor, fuel rail etc etc $400
Turbo setup, 3" dump pipe, 3" front pipe, Turbo, lines etc etc.. $300
Intercooler setup all pipes intercooler etc, $120
Liverpool NSW will ship at buyers expence and $30 handeling fee otherwise free pick up
0421377199
You wouldn't happen to be selling the airbox + snorkel would you? if you are let me know a price please if not best of luck with the sales.
Cheers
If ISEEKOOL is only after the turbo I will take the dump pipe and front pipe delivered to Adelaide 5067, need one for my 34
Giulian
turbo sold..!
only thing left are the oil and water lines.. and intercooler setup..!
intercooler and piping $100..! cheap..!
Edited by ff_driftz
TXTed you about cooler & piping, can pickup this friday.
Edited by putraged
