Ok so i need to move in a few weeks and no longer need any of these parts as they have all been upgraded.. Can get more specific photos on request.
All items Located in penrith area NSW.. All prices are listed as ONO, worst i can say is no but nothing stupid please.
PM Me or Txt 0412589924
r34 GTT brake master+ booster $100+ post
perfect working order removed for a 33 gtr setup.
HKS split dump pipe +r34gtt oxy sensor to suit 3037/3076 or any GT 30 based turbo with a 5 bolt rear housing (I have a .86 int gate rear housing to suit for extra if interested)
It is used for approx 2000kms but removed to go ext gate setup. $200
RB26 clear timing cover painted 34 GTR red.. Was going to go with rb 26 covers but CBF anymore. $50 + postage
R34 GTT Half shafts+ Driveshafts. Suits any nissan with a 5 bolt half shaft and half shafts suit r34 gtt standard diffs.
Removed from my car for GTR shafts and a 2 way $100+postage which is half of what you would pay from a wreckers and these are ALOT better looked after
has a little bit of oil spilt on them but boots are great and perfect working order.
R34 standard flywheel $50
its flat with no heat spots etc removed to go a lightened flywheel
SARD universal battery relocation kit $350.. was going to use it on my car and run a GTR type catch can but dont need to anymore.
BRAND NEW only opened for pics, still has all the protective covers and bubble wrap etc
if you wanna see what it looks like properly look here: http://www.rhdjapan....minal-kit-21791
R34 GTT impul front bar $50 PICKUP ONLY bought from carmate to use as a Texi/track bar, it has cracks from hitting cones and shit but still mounts straight etc
would need a repair and paint to fit to a street car.
S15 Vertex side skits. $150 ono
FPR Has some scratches but is quite solid and mounts straight
THIS IS A SCRATCH NOT A CRACK
now for the random junk, throw me an offer.
R34 LED tail lights. East bear copies that came on the car but the red lenses have faded so you can either tint/nightshade them or put your existing lenses on these to get a cool LED style. It was my original intention to do just this but 2 jobs means no time for car crap like this. $40?? this is the only photo i can find on my PC
R34 GT standard ECU $20 good for someone with a blown board or if you just want the housing to put a Link G4 board in etc.
R34 standard GT injectors $20 good for a highflow otherwise ill just chuck em
https://www.sau.com.au/forums/topic/393330-aggromans-garage-sale/
dump sold pending pickup and payment.
Master+booster now $80
Timing Cover & flywheel $30 each
Sard Battery Relocation kit $300 (over 100 off what you would pay landed)
  • 3 weeks later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
