FOR SALE
A SET OF LIKE NEW GANADOR MIRRORS $450.00
A SET OF GTR TURBOS(minimum shaft play)& DUMPS $300.00
FUEL RAIL $50.00
WALHBRO FUEL PUMP GS342 BRAND NEW IN BOX $120.00
GTR STANDARD CAM GEARS $100.00
TURBO TIMER $50.00
R32 GTR FRONT GRILL(like new in silver) $150.00
R32 GTR REAR SPOILER(silver) $250.00
LIKE NEW SET OF RIMS AND TYRES 18/9.5/265 ALLROUND (see pictures in gallery) $950.00 or swap for jap style rims
MAKE ME AN OFFER.....pictures can be emailed/sms
https://www.sau.com.au/forums/topic/393360-mirrorsgtr-turbos-and-dumps/
Located in Camden , NSW
Picture has been emailed.
Make me an offer on all parts , all must go to finance a engine build.
Others parts available soon.
Striping RB26 , let me know what you need.
In the Stagea forum there is a guy in the UK after, maybe, Rb26 loom. Check him out.
All reduced:
Mirrors now $400.
Turbos with very minimum shaft play now $250 with dumps
Fuel rail $50
Front grill SOLD
Rear spoiler SOLD
Turbo Timer $30
Konig rims with like new tyres 18/35/265 now $900
Rb26tt motor standard , without computer & turbos , low compression. $2500
All must go
Call/SMS 0422370051
post-83894-0-01030500-1331286888_thumb.jpegpost-83894-0-16650400-1331286768_thumb.jpg
All reduced:
Mirrors NOW $400
Turbos with very minimum shaft play NOW $250 with dumps
Fuel rail $50
Front grill SOLD
Rear spoiler SOLD
Turbo Timer $30.
Konig rims with like new tyres 18/35/265 NOW $900.
Rb26tt motor standard , without computer & turbos , low compression. $2500 NOW $2000.
All must go
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
