Hi Guys,
I have a newish Haltech E11 V2 With Plug In Harness For Rb26 up for sale. It was new about 800kms ago.
Uppgraded to a Haltech Sports 2000 that I got new off a mate for a great price.So this Haltech needs to go.
$1000 ono
Cheers
Richard
Hey, what where the negatives that made you Upgrade?
Considering aftermarket ecu & loom,heard at idle they all hunt which would be annoying.
Your input would be appreciated.
Hey Paul - Ive never had the hunt Idle issue but I may go and have search to see what others are saying. Maybe bad tuner or set-up ??? dunno. Also peeps talk about Haltechs that were over 10 years old and still bag em as they haven't moved on although technology has heaps.
I had a great opportunity to pick up the cream of the Haltech crop new at a basement price so I jumped on it. It will allow me to make any modifications knowing my current ECU is more than capable.
I didn't have any down sides with my E11v2. I did do a large amount of research and it boiled down to 2 - Haltech or Vipec. I asked for a Haltech Platinum Pro and thought I had one until I fixed up the kick panel and found I had a new E11v2. Checked my invoice and found the shop had substituted it without my knowledge. No issues experienced, and 326awkws on -7's at 18psi :)
Maybe they had this one in stock and not the one I asked for or maybe they though the E11v2 was more than what I needed and the Pro was overkill. Just dont know and not worth the hassle to follow-up on.
Anyhow fire away. Happy to answer questions. Maybe do some searching or posts in the forced induction thread.
Cheers
Richard
Yep - your right a Price drop :D
$800 bucks
Get amongst it - couldnt be cheaper for one of the best ECU's in its class with the Plug in Harness.
You folks are are tighter than a fishes ar$e. bloody waterproof your so tight! pinch.gif
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
