Gday All, got my cefiro up and running with a few mods(car was bought minus motor and box). It seems to go ok by the seat of my pants
but after a short drive I pulled my plugs to check the gap (0.8mm)and this is what they look like.
It is already booked in for a dyno this week but the shop is 1/2 an hour away-is this safe to drive that far?
Mods:
Bosch 044 fuel pump
GTR injectors-clean and tested ok
Z32 AFM
GT2871 turbo
FMIC
3 inch turbo back exhaust
ECU remap-tuner has checked and confirmed against his other files that its correct for my mods.
thanks for any help
Jes
https://www.sau.com.au/forums/topic/394194-is-this-lean/
Yeah these are copper plugs, I didnt know whether to go 6 or 7 heat series as there are tons of guys doing both,
my tuner said 6 so I did that. what would the difference be with a 7 plug?
Jes
it's just a safe measure, 7 will stay cooler when the engine is running above standard measures. Lower the risk of pre ignition. Repco should have them, super shit won't.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268006
Its very hard to tell lean and rich from plugs when you are running fuel with no lead in it.
What I can tell you is that your cylinder temps are too cold for that plug or your plug is too cold for your cylinder temps.
The white porcelain of the plug should be clean and white much further up the plug than where it is.
You could run a 5 in your engine, or lean it out to up your cylinder temps.
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268028
His op said, new plugs out after a short drive. I really doubt that short drive is substantial time to darken the porcelain...
https://www.sau.com.au/forums/topic/394194-is-this-lean/#findComment-6268667
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
