How old are u slylinerz???
  • Replies 241
Originally posted by funkymonkey
if dats MZNISMO I've seen her sumwhere (no not on an MCCR cruise) god knows.
nark u'r jus an overgrown samoan...
Denham how come u din drive your excel to the cruise? I wanna see HRD CNT! :)
I dunno bout ex-static to give him shit so :D
/me hides
u might has seen amber on the podiums of brass monkeys!!
she loves that place!
as for u inark u will keep:mad:
lol one of my friends has an affinity for podium dancing at brass monkey too... i know what you mean.
Hmm it's been a while since I've been there... argh its on tonight, bah cbf driving all the way to hallam... hey did you hear, apparently 4 ppl have caught meninja****le from brassmonkey...
That nasty strain might have spwaned from MZNISMO as she likes to wear short skirts with no paties and rub her punani all over the poles while dancing!!:bahaha:
Originally posted by MZNISMO
heya brendan!! im good thanks how u doing!
denham ur last post is just a clear example of how sexually frustrated u must be to have to result in fantasing about myself doing such things :bahaha:
hahaha u wish babe! its not fantasy babe, its all on the security camera tapes!
ps. i think ex-static likes u!:D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
