hey didnt know where to post this so i gathered here was the right spot. im looking at buying a GQ patrol diesel. i have searched the 4x4 forums with no luck. however my question is how good/ reliable is the nissan RD28 turbo diesel and is it good offroad etc.
https://www.sau.com.au/forums/topic/394655-nissan-rd28-turbo-diesel/
^some of the older GQ's did come out with a RB30, hard to find as they were not popular at the time. problem is they are 2.5 ton plus so need to work and rev the rb30 hard to make it work, better of with a big turbo diesel and go from there, massive torque low revs
I've seen some people put RB25DET, RB25/30DET witha massive snail attached - no issues with a "lack" of torque.
Rather amusing watching watching all 4 mud tires turning into smoke.
^^ wise move. if you find another 2.8 or 3L you will be looking at about 6K for the 4.2 change over gearbox and engine if you want to go that way. which is probably cheaper than trying to find a good 4.2 staight away. look for a good body rather than engine
  • 1 month later...
Had a 4.2 on LPG, now have a 4.5, I could not recommend one highly enough!! Compare some prices, compare what you get for the $$s, I got a 98 Gu st, with 240k lift kit, steel bar, driving lights, electric brakes snorkel etc for $13500. Gas is pretty pricey in bathurst, and off $85 I get 500k going back and forward to work. Too many people get caught up thinking that the td is the only one to buy, and pay twice the price of an LPG powered one. Use 1/4 of what you saved chucking a 3071 on it, and it will blow a td away
That's interesting v8tzr. Could you give me a heads up about an SD33 non turbo. I bought my Dad's old 85 MQ Patrol off him about four years ago - he had it since new. It has now clocked 270,000 on the clock and everything is stock and original - anything I need to look out for etc?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
