Just to clear it up these guys dont make ones cheap for 33 gtst's do they? :(
To be honest mate I really don't know. They don't even list Skyline on their site so what I've done is searched by the Bilstein part number. I guess if it appears in Bilstein catalogue then just hit up google and you may get lucky.
  • Replies 74
Posted Images
Bilsteins have arrived. In my possession!!!
I will be getting them installed on the weekend. Any tips/tricks I should know?
Can't wait to get them on the road.
For any would be purchasers, I ordered them on the 7th of May, shipping commenced on the 11th and I recieved them on the 29th. 3 week turnaround.
As a special bonus, I did not get whacked with any customs or GST at all....boooom!! Total cost AU$1240
Awesome man - lucky with the customs, I got smashed though so I expect you to get a first round of beers :cheers:
Actually, I have something to ask - get you see if you can remove the sleeve, ABS securing tab, that has a small metal tab welded on it from the fronts - You need to remove both springs (main and keeper), springs seats and the top large adjuster nut.
Why I'm asking that is that the sleeve, in between two adjuster nuts, positions the bottom adjuster really low so you can't really lower the car that much. Without the sleeve the bottom adjuster nut will sit just underneath the big adjuster, just like it does on the rears, and instead of the silly sleeve you can just use hose clamps or something similar to secure the ABS cable.
Let me know if you can remove it - you may need to slide it over the blue plastic shroud, or see if that can be also removed. Shouldn't take more than 5mins if you still don't have top hats on the suckers.
cheers
Bel
I'll have a look at it when I'm at the mechanics. I am not interested in being that low anymore. I have Hipermax on now and with the V-Spec front diffuser its a massive bitch!
Do I'm looking to add some height if anything.
I will see what the mechanic reckons about taking that sleeve off.
http://www.heasmans.com.au/new_site2/pdfs/Bilstein%20B16.pdf
Check that out. Looks like they make them for all GTRs.
Not sure that the part number is.
Got them installed today. Not sure about the sleeve still unfortunately. Maybe call Heasmans in Sydney, they will be able to tell you. (02) 9516 1182
They are soooo much better than my Hipermax. Bumps are way less harsh. Its like a new car.
Thanks for the link. I managed to get the part number off there.
Just tried ordering off the TVH website but the german language has thrown me off. I've emailed them so hopefully I'll get a response on how to order.
Good to hear they're going well. I can't wait to replace my teins in the gtr :)
Yeah that's the problem I had. I was going to go through them but it doesn't look like they sell the PSS9s for the R32 model. The TVH does list the 32 model but it's all in a different language. I've sent them both an email so hopefully I get a reply.
Edited by Chris32R
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
