Post up a pic of your Keitai! (Mobile Phone)
Has served me well in the 6 months that I've had it... Panasonic P505iS: 1.3 megapixel, 20x digital zoom, 64 meg Mini SD memory card, 3 mins total video rec time, and last but not least... a barcode reader (?)
Damnit, we Aussies miss out on all the good stuff!
Actually, I think Australia is lagging behind Japan about 1 year or so when it comes to mobile phones.
On another note, I saw that Plasma TVs and LCD flat panel TVs were almost as common in Australia as Japan... REALLY suprising... (exept in Japan the flatscreen CRT TV is almost dead, whereas in Australia thet still had a good selection).
Australia is not too bad as far as mobile tech goes: sure, we can't touch Japan, but at least we are not in the pre-historic ages like the US :rofl:
funkymonkey: helps that the major producers of LCD panels are Korean of course *cough* LG *cough* Samsung.
LW.
Here is mine...taken from the Vodafone site(black one).
http://www.vodafone.jp/english/products/ki...h010/index.html
Served me well for a year now...but due to it having been dropped many times it plays weird triks on me:p
I like the one with the TV tuner....what an invention...excellent quality as well!!
Anyway its amazing what a differance a year makes in the mobile phone market...
:D
Not so sure about the TV tuner one, not if you're in Yamanashi - you can only receive 2 channels clearly! :P
Watching TV and then taking a few calls would just about run the battery down too...
there's decent stuff out there, but not many resellers in Australia wanna seem to wanna get stuff from there. orange has sorta brushed the surface, but manufacturers like LG, Hitachi and Sanyo n Samsung all have AWESOME phons for the 3G networks, its a shame the 3G infrastructure in aus is still in its infancy. Once 3G kicks off full shwing then we'll kick Japan's ass.
Japans adavanced phone system was due to it pioneering telecomms department in govt. Wheras here we had telstra with a stranfglehold on what can and cannot be done. With telstra fully privatised that should be a thing of the past and new exciting stuff should be available soon.
I don't think Japan has anything to be jealous about when it comes to mobile phone services in other countries. Cheap phones, continuous new products, great service, never a problem, excellent coverage and getting better FAST, fair charges...do I need to go on? In fact the only thing that you can't do here in Japan compared to overseas is use the same number if you change service. They are working on this and it should be available in the next few years...
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
