Post up a pic of your Keitai! (Mobile Phone)
Has served me well in the 6 months that I've had it... Panasonic P505iS: 1.3 megapixel, 20x digital zoom, 64 meg Mini SD memory card, 3 mins total video rec time, and last but not least... a barcode reader (?)
Damnit, we Aussies miss out on all the good stuff!
Actually, I think Australia is lagging behind Japan about 1 year or so when it comes to mobile phones.
On another note, I saw that Plasma TVs and LCD flat panel TVs were almost as common in Australia as Japan... REALLY suprising... (exept in Japan the flatscreen CRT TV is almost dead, whereas in Australia thet still had a good selection).
Australia is not too bad as far as mobile tech goes: sure, we can't touch Japan, but at least we are not in the pre-historic ages like the US :rofl:
funkymonkey: helps that the major producers of LCD panels are Korean of course *cough* LG *cough* Samsung.
LW.
Here is mine...taken from the Vodafone site(black one).
http://www.vodafone.jp/english/products/ki...h010/index.html
Served me well for a year now...but due to it having been dropped many times it plays weird triks on me:p
I like the one with the TV tuner....what an invention...excellent quality as well!!
Anyway its amazing what a differance a year makes in the mobile phone market...
:D
Not so sure about the TV tuner one, not if you're in Yamanashi - you can only receive 2 channels clearly! :P
Watching TV and then taking a few calls would just about run the battery down too...
there's decent stuff out there, but not many resellers in Australia wanna seem to wanna get stuff from there. orange has sorta brushed the surface, but manufacturers like LG, Hitachi and Sanyo n Samsung all have AWESOME phons for the 3G networks, its a shame the 3G infrastructure in aus is still in its infancy. Once 3G kicks off full shwing then we'll kick Japan's ass.
Japans adavanced phone system was due to it pioneering telecomms department in govt. Wheras here we had telstra with a stranfglehold on what can and cannot be done. With telstra fully privatised that should be a thing of the past and new exciting stuff should be available soon.
I don't think Japan has anything to be jealous about when it comes to mobile phone services in other countries. Cheap phones, continuous new products, great service, never a problem, excellent coverage and getting better FAST, fair charges...do I need to go on? In fact the only thing that you can't do here in Japan compared to overseas is use the same number if you change service. They are working on this and it should be available in the next few years...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
