Hey all,
Just curious on a little issue. I'm looking to get more response out of my rb25, i've been playing around with the idea of putting in a light weight flywheel. I've heard that you can get some pretty good results from it but i'm still in need of a bit of convincing. Someone with experience with this drive train modification please enlighten this :newbie:
Thanks
https://www.sau.com.au/forums/topic/39519-engine-response/
I don't have any expereince with it, but i'm planning to put a light weight flywheel in when i do my clutch next, it should give it that little bit more response/rev a little quicker...
anything you can do to lighten up the drivetrain has got to be good for responsivness
https://www.sau.com.au/forums/topic/39519-engine-response/#findComment-802480
a lightened flywheel will help improve pick up response, but be aware that it will also cause the revs to drop more during gear changes...
Dave has a good point here - if it'll rev faster, it'll DE-rev faster too... i guess it depends on how you want to drive it. IMHO, i would have thought that for dragging, maintaining revs would have been more important than quick throottle response ? don't quote me on that though...
https://www.sau.com.au/forums/topic/39519-engine-response/#findComment-802494
Lightened flywheel, lightened wheels, lightened tail shaft, lightened pulleys are all good.
But you can also lighten your car - rip up the carpet and remove all the sound deadening, remove the boot trim and the spare wheel, remove the rear seats.
Not only will you increase responsiveness, as the car gets lighter, it brakes and corners better too. If you can remove 70-80kg - that have as much difference as between when you have a passenger in the car and when you drive alone - every bit helps.
If you have management, get it tuned with AF ratios around 11:1 and add more timing - this too will increase responsiveness. Its how one of Signal's D1 drivers suggested I should tune my car to increase responsiveness. He also suggested that running a base fuel pressure of 3kg (instead of stock 2.5) would help, with the right tune, to increase response further.
https://www.sau.com.au/forums/topic/39519-engine-response/#findComment-802499
mmm thanks all.. has given me a little food for thought.... more comments please:D
yeh the flywheel and a light alloy pully system should be good... what i want to do with the car is just make it a little more responsive....... not jack the boost up and make it go nuts.... just enhance whats already there. Sorta like trying to play with the car in a little different manner. :)
https://www.sau.com.au/forums/topic/39519-engine-response/#findComment-803124
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
