Got this lying around
old school cool with what appears to be a t04 turbo of some description plus dump, wastegate and screamer
manifold and wastegate is genuine HKS, can't confirm about turbo though
will make your rb20/rb25det skid alot
$1200
Pick up valley heights sydney or can ship
https://www.sau.com.au/forums/topic/395369-hks-low-mount-turbo-kit/
is there play in the turbo and what rear housing is on it.?
what power was it making any dyno print outs ?
does wastgate hold boost and how much ?
is manifold cracked anywhere and what condition is it in i.e how bad is the rust on it or is it light rust cos the car looks as if it has been sitting around for a bit, ?
also is cold side cooler piping included & air filter pipe to turbo ?
Thanks Mate
Edited by WARLORD
Thanks Mate
it's on the car.... it runs lol
yea haven't pulled it off yet mate
welcome to come inspect otherwise i'll have it off in a week or so :)
  • 3 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
