Pick up from Blue Mtns or Sydney preferred.
Lay-By if your budget is tight - and you have up to 1 yr to pay it off.
Number 1)
Item: MINE'S CATBACK EXHAUST (R34 GT-R) for $790ono
Description: Rare & Beautiful 80mm S/S Exhaust. It has one of the most gorgeous tips too. System is not that old. So no scratches or dents.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/
  • Replies 76
Number 3)
Item: NISMO CALSONIC 3" S/S Exhaust (r34 GT-R) for $350
Description: This could be 10 yrs old - but good condition.
Lay-By will be accepted here too. Centre muffler has slight scraping, but nothing harsh.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283688
Number 4)
Item: HKS Front Pipe (R34 GT-R). $390
Description: This Y-Pipe has a foldover to equalize lengths > 3". Not that old. Gorgeous - no scrapes.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283692
Number 5)
Item: HKS 3" Cat. Looks like about 200cfm. $335.
Description: Heat shield and S/S Cat look to be in great condition. Minimal constriction at either end. No rattles that I can hear.
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283693
Number 6)<br>Item: NISSAN Bonnet Struts for $0 = Free to a good home<br>Description: These need to be regassed. Want to make your engin bay look classy?<br>No Lay-By on these - LOL<br><br>Terry-225.jpg<br>
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6283695
Nismo system should come up well with some elbow grease ie steel wool scourers
Yes it will, with some...
a) Prepsol 'n steel wool then
b) Autosol then
I think I'll have a go myself on the weekend if I have time and update Pics if it hasn't been taken.
Thanks
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284317
Terry, can you chuck up the sizes of the Hooker Muffler? (width and length)
Ta
A
Sure...
Without the piped flanges,
Body Width = 280mm
Body Length = 365mm
A, It comes with installation instructions + embossed words "INLET" and "OUTLET" on the muffler itself
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284327
Sure...
Body Width = 280mm
Body Length = 365mm
Cheers tez. Will measure under the car and let you know
https://www.sau.com.au/forums/topic/395467-terrys-exhaustd/#findComment-6284529
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
