g35driver.com has a detailed write-up. its a big job - colour is part of the gauge face. you could carefully sand it off... you could also just as easily ruin the guage face.
but theres no point doing just one part of the dash. it will look out of place. you need to mod every single globe on the dash and radio or none at all
https://www.sau.com.au/forums/topic/395706-dash-lights/#findComment-6287972
