Do you love the look of copy rims, but just arent baller enough to by chinese?
Enjoy having 1968 Cabernet Sauvignon but siphon it into a goon bag to not look too fancy?
Do you wish people kept saying "Nice drift teks" just after they said to your mate with TE's "nice rota grids"
Then buy these rims .......
They are genuine URAS NS-01's
They are what the TE37 is to the Rota Grid.... but to the drift tek
Pretty much look boss on anything with 5 studs and not gay (so no subie, honda, modern yota)
Set of 4, thats right, one of the few sets of rims that I own im thinking of letting go of
Bought these babies for a substantual amount of cash, you know in a time where people didn't blink at spending close to 2k on rims. Was about 3 years ago, about a month or 2 after I bought my 14 and have been on it in some way most of the time I've owned it.
As the 14 is track only I dont really need 5-6 pairs of skidders no need to clear the garage a bit.
They are in suprisingly good condition.
all rims have very light scratches on face
they all have very light rash on the lips from rocking streach the whole time
one has about a 10cm deep rash from clipping a gutter while parking
the are the holy size
17in in diamiter..... Cheap tyres from semis to chinas it easy to find something
9.5in all round..... Not to wide to run into inner clearance issues, but fat enough
+15 Offset all round..... Fill out near any stock gaurd
Not quite silver, not quite alloy.... just awesome
So once again thats 17x9.5+15 all round
They will look boss on any S or R chassis with just strech and a gaurd roll, no flare needed
They love strech and can take a 215 all day everyday
What am I asking for these lovley scamps
$1100 Rims alone
$1500 Rims + 70% 215 KU36 semi slicks and brand new cheapie 215s
$1800 as above with a spare pair of Work Equips 17x9+20 for skidders
https://www.sau.com.au/forums/topic/395930-17x9515-uras-ns-01/
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
