Hi Guys,
Before u flame i did search and was unable to find solutions to my issue.
Ok well i have just purchased a S1 R33GTST and noticed the following...
It seems like something electrical is causing my rev tacho 'OEM' to jump around like crazy, hopefully this is an common issue and can be sorted without too much fuss, i bang the dash a lil and goes back to normal but i dont like beating my car ahaha.
Also can some1 hook me up in Perth area with some strut braces to suit?
Much thanks,
Smitherines..
https://www.sau.com.au/forums/topic/395943-r33gtst/
Also, check my job on restoring the headlights :-)
Pretty stoked on the outcome.
I originally intended to keep the lights on the car but found 1 had water in it so i baked and re-sealed.
I have coated the lights in 3 x layers of UV protectant to avoid this happening again.
Yellowing = GAY
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6290176
Also, I noticed this plug without any harness going to it>>> ?? WTF!
Has anyone seen anything like this before?
Also found this RSR certificate, whats this? ref pic.
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6290649
Yes it is the throttle sensor, my car runs like sht when im mucking around and forget to plug it in!
you will find some broken wires somewhere unless you have some ecu that dont need it (doubt it)
Also see a vac line missing, there important for proper turbo/inducion operation
Edited by D.I.Y. Mik
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6291050
Next job's to fix...
Rev tacho has finally stopped working totally, so i will remove in the morning and suss out.
The hi-cas light comes on now after about 10mins and stays lit, i have searched around and found that it could be due to the after market boss kit, if anyone has pointers for this help me out please. Tried the diagnose function but couldn't seem to get it in that mode??? help...
But after re-calibrating the TPS the car runs like a hot curry :banana:
Also i will say that it seems i have had no help from many on here which is a little of a let down :thumbsup:
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6292736
Thanks mate, i found this vid the other day and tried to go into diagnosis mode but it didnt do it, i've tried like 10 times... i've just bought the car so i might have a look around n see if the is a there is a tomei hicas lock unit on the hicas unit...
Any reason why no1 is helping me out?
Regarding solder joints, i had the tacho out this morning and couldnt see where solder is used, did you have a rundown of this??
Thanks again.
Oh and i think i know maybe why its not going into diag mode, the after market steering wheel????
Edited by HR31DRFT
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6294886
iirc you may need to get a hicas adapter / boss kit..
it took me a few tries but you have to turn it quickly to engage it.. but if you have done that it could be the steering wheel.. the above video the guy has an aftermarket steering wheel so it may be something else..
the tacho may be a wiring issue also
https://www.sau.com.au/forums/topic/395943-r33gtst/#findComment-6295107
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
