Hi,
I feel very stupid as heading states I hooked up fuel lines wrong way round. Just put my rb26 in my car and connected them up not thinking just so fuel didnt drip everywhere and to get them out of the way.
I hooked up wiring and fuel pump and starter, I just wanted to turn it over after rebuild, turned key to accessory and fuel pump started. meanwhile i could hear a strange pressure building noise and quickly switched it off.
very soon after i realised that fuel pressure had built and obviously couldnt get past the fuel reg and fuel passed through the injectors into the cylinders.
Q 1. are my injectors going to be okay after that sort of abuse.?
Q 2. is my fuel reg going to be okay?
Q 3. will this effect run in and the hone job on the bores or the rings themselves? (Fuel was pushed out of cylindars within half an hour.)
Q 4. Will I not know any of the above until I test each thing.
Thanks
Taylor.
I don't understand, I hooked mine up the wrong way as well once and fuel just didn't get past the reg, so how has it got into your cylinders ?
fuel shouldn't get past the reg the wrong way and pump should turn off once pressurized
I assume it pressurised the injectors so much they leaked out the tip. fuel got into the cylinders through the injector tip. fuel pump didnt switch off once pressurised it just kept pumping and filled the cylinders in seconds
on an rb26 the rails pressure reg is on the front of the rail itself before the injectors. the lines were reversed so the fuel went to all of the injectors first and stopped at the reg at the end and i assume couldnt get past the reg
Reg is definitely on return side cause it needs to regulate pressure in the rail..
so sounds like it is hooked up the right way..
So either your pump isn't switching itself off once pressurized, have your rewired it lately?
Or your injectors are stuck open for some reason..
maybe your injectors are getting voltage I dont know why this would happen
I had 90psi fuel pressure on mine and it wasn't enough to push injectors open, then again my pump would switch off..
Fuel can't get past the reg and even if it does you won't have much pressure in the rail because there is nothing to stop it running back to the tank.
The reg restricts flow back to the thank to increase pressure in the rail.
Your injectors, reg and engine will be fine.
If you're really scared and want to be sure pull the spark plugs out and crank the engine over with the cam angle sensor disconnected to clear out any fuel in the bores.
Id say more then getting the line's the wrong way you have leaking injector seals? Or the reg jammed shut over pressurising the rail causing fuel to leak past the injectors?
Everything would now have been washed of any oil on its surface. Id drain everything, leak everything open for a few days to let any fuel evaporate out then refill with oil, then crank it by hand for a while?
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
