Sorry guys :P
a. I didnt even know there was damage on MattRs car cos it was the smallest bump ever. I think I found out later that it cost 100
b. I didnt think people would get pissed off from dyno day considering people do that stuff all the time on cruzes
c.I always post informative posts.
I think im gonna run away and hide now.
  • Replies 78
right whatsisname thats enough out of you. watch you're mouth of i'll report you're post to joel! :P
:( No need to report my post Tim, I've already reported it... to ME!
arrrh we all love hanging the arse out once and a while otherwise we would own gemini's, nothing like the feeling of nissan lsd kicking in
some people just get bit excited when they go to dyno's tis like a little kid in a candy store
Erin
the RED gemin with the black bonnet from the drift day seemed to "hang its ass out " quiet nicely! i wouldnt mind one like that! :boinkcar:
Dean, no offence particularly meant, and I am certianly not one to point a finger when it comes to playing up every now and then, but there is DEFINITELY a time and place - and I choose mine VERY carefully.
dude, what was the location's proximity to
a) houses
B) businesses
and c) thoroughfare traffic (at that time of the morning)?
Answer: effectively the middle of nowhere :)
I'm sorry a Gemini does not have a right to be on the road anymore, let alone a drift track ... sorry Steve :)
Well some people have different taste and theres nothing we can do bout it. I actually think its good that people try to be different.
Also, i dont know if any of use remember the Gemini wit the rb30 from the drift comp a while back......
Well that now has a vg30 turbs, cooler and locker. Now that is one tough Gemi that id even like in my drive way!!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
